10-01-2014, 13:01 | #3 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @aliburhan1 Install 11.70 just released today. If still problem, then maybe you are using 64-BIT machine? If so, then try to swap dll... Go to: C:\AdvanceBox Turbo Flasher\OpenSSL\DLL_32-BIT\ Copy 2 DLL files there, then paste it here: C:\AdvanceBox Turbo Flasher\ Overwrite the 2 original files there. |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
10-01-2014, 13:07 | #4 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Lahore Age: 38
Member: 1016490 Status: Offline Thanks Meter: 290 | Quote:
The Following User Says Thank You to sajidshah50 For This Useful Post: |
10-02-2014, 15:29 | #8 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | After you install ATF 11.70, you will see 2 Folders inside C:\AdvanceBox Turbo Flasher\OpenSSL\ DLL_32-BIT DLL_64-BIT Now inside each folder are 2 dll Files... Try First to copy the 2 files from DLL_32-BIT, and paste it to C:\AdvanceBox Turbo Flasher\ overwrite the current files there... if that does not work and still Invalid Response, then try the other 2 dlls inside DLL_64-BIT folder. |
