Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 09-24-2014, 16:12   #46 (permalink)
Member: 60676
Originally Posted by Advance-Box View Post
@ALL
Seems DNS Server still have problems in other countries...
So solution for now is this:
Copy paste this:
174.120.45.28 www.advanceturboflasher.com
174.120.45.29 www.atf-lightning.com
If this will work for most users, then I will make next ATF exe do this automatically during start up.
B.R.
Donīt work for me. i send you the teamviwer id and pass
Regards
Old 09-24-2014, 16:17   #47 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
@ALL
Problem found and solved, thanks to AZEEM!
For Some windows machine like XP, you need to put 2 DLLs inside
C:\AdvanceBox Turbo Flasher\
Together with AdvanceBox.exe ...
2 DLLs can be downloaded here:
For 32-bit Windows XP, Vista, 7, 8, 8.1
http://174.120.45.27/tmp/OPEN_SSL_32_BIT.rar
For 64-bit Windows XP, Vista, 7, 8, 8.1
http://174.120.45.27/tmp/OPEN_SSL_64_BIT.rar
Just extract the RAR file to get the 2 DLL, and put it together with AdvanceBox.exe
It should work now.
So final update will include these 2 dll + auto install.
B.R.
The Following 11 Users Say Thank You to Advance-Box For This Useful Post:
Old 09-24-2014, 16:28   #48 (permalink)
Member: 60676
@ALL
It should work now.
B.R.
Perfect 1000%
Regards
Old 09-24-2014, 18:16   #49 (permalink)
Member: 1769097
Sonork: 1001597271
Thanks Meter: 35
@ALL
It should work now.
B.R.
not working with me ...........
The Following User Says Thank You to MOBILE CONTROL For This Useful Post:
Old 09-24-2014, 18:28   #50 (permalink)
nicnec's Avatar
Member: 50585
Thanks Meter: 63
@ALL
It should work now.
B.R.
this solution works!
thanks!
Old 09-24-2014, 18:30   #51 (permalink)
Member: 651945
@MOBILE CONTROL
If not working, then you also need to do hosts file edit
Also make sure you are really using 11.70 PRE-FINAL
Old 09-24-2014, 18:42   #52 (permalink)
.:iTRi:.'s Avatar
Member: 240068
Thanks Meter: 201
cant run new exe
any solution
Old 09-25-2014, 01:22   #53 (permalink)
Member: 1095445
ATF NItro no work---i do this copy AdvanceBox.exe, dll archive and edit host::::no work????
Old 09-25-2014, 01:54   #54 (permalink)
Member: 651945
@xangelito
Show screenshot.
Old 09-25-2014, 02:41   #55 (permalink)
Crazy Poster
Member: 172354
Sonork: 100.1608773
its working now...with 2dll file...thanks
Old 09-25-2014, 02:58   #56 (permalink)
Member: 1494304
Sonork: 100.1606186
Thanks Meter: 108
working fine now with 2 dll file
thanks team for finding better solution
Old 09-25-2014, 03:13   #57 (permalink)
hungco's Avatar
Member: 223718
Thanks Meter: 40
Requesting Authorization Code
ERROR: Server Response Invalid or Rerouted 0x03
How to fix it?
Old 09-25-2014, 03:14   #58 (permalink)
hungco's Avatar
Member: 223718
Thanks Meter: 40
How to fix it?
Old 09-25-2014, 03:25   #59 (permalink)
hungco's Avatar
Member: 223718
Thanks Meter: 40
How to fix it?
Old 09-25-2014, 04:06   #60 (permalink)
anoamocreative's Avatar
Member: 919549
Thanks Meter: 132
It working fine right now
Thanks sir
Page generated in 0.27667 seconds with 9 queries
