10-03-2014, 07:09 | #109 (permalink) |
Freak Poster Join Date: Jun 2012
Member: 1776947 Status: Offline Sonork: 100.1659966:tjjxxs Thanks Meter: 74 | ATF server connection error s symble solution first install 11.60 then replace 11.70 to ATF folder THEN the file to atf folder download link OPEN_SSL_32_BIT - Download - 4shared |
The Following User Says Thank You to tjjxxs For This Useful Post: |
10-03-2014, 08:15 | #110 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | After you install ATF 11.70, you will see 2 Folders inside C:\AdvanceBox Turbo Flasher\OpenSSL\ DLL_32-BIT DLL_64-BIT Now inside each folder are 2 dll Files... Try First to copy the 2 files from DLL_32-BIT, and paste it to C:\AdvanceBox Turbo Flasher\ overwrite the current files there... if that does not work and still Invalid Response, then try the other 2 dlls inside DLL_64-BIT folder. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
10-03-2014, 19:45 | #111 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,345 | Yes Confirm. @amcti_gsm, Atf 11.60 must need of Uninstall first. After that Install 11.70 Full version, extract the 2 DLL from OPEN SSL 32/64 BIT and copy/paste in C:\AdvanceBox Turbo Flasher\. Why you have done IT?: Quote:
Br | |
The Following User Says Thank You to allumts For This Useful Post: |
10-11-2014, 15:36 | #113 (permalink) |
Junior Member Join Date: Aug 2014
Member: 2236725 Status: Offline Thanks Meter: 0 | my skype is constantine0307 and i having seriuos problems with my atf box,please somebody find me on skype and help ,i would really be happy is someone could fix my problem relating with atf |
10-11-2014, 16:40 | #114 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,345 | Quote:
Br allumts | |
10-13-2014, 10:27 | #118 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Next time use your eyes to read post #112 If you cannot understand post #112 here is another thread which tells you exactly the same thing. http://forum.gsmhosting.com/vbb/f609...ponse-1864764/ If you still cannot understand that, try reading it 100 times. |
