Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 10-01-2014, 17:00   #106 (permalink)
Automatico's Avatar
Member: 2140790
Sonork: 100.1679059
Thanks Meter: 212
I cant found a solution for me Windows 7 Professional 64bit
Waiting Help
aUt0
Old 10-03-2014, 06:42   #107 (permalink)
dilbarkhan's Avatar
Member: 1814786
Sonork: 100.1619255
Thanks Meter: 37
for new setup errer is solve thanks for new update
Old 10-03-2014, 06:46   #108 (permalink)
dilbarkhan's Avatar
Member: 1814786
Sonork: 100.1619255
Thanks Meter: 37
Use atf 11.70 full setup intall it well solve problam
Old 10-03-2014, 07:09   #109 (permalink)
Member: 1776947
Sonork: 100.1659966:tjjxxs
Thanks Meter: 74
Thumbs up ATF server connection error s symble solution
first install 11.60 then replace 11.70 to ATF folder THEN the file to atf folder
download link
OPEN_SSL_32_BIT - Download - 4shared
The Following User Says Thank You to tjjxxs For This Useful Post:
Old 10-03-2014, 08:15   #110 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
After you install ATF 11.70, you will see 2 Folders inside
C:\AdvanceBox Turbo Flasher\OpenSSL\
DLL_32-BIT
DLL_64-BIT
Now inside each folder are 2 dll Files...
Try First to copy the 2 files from DLL_32-BIT, and paste it to
overwrite the current files there...
if that does not work and still Invalid Response, then try the other 2 dlls inside DLL_64-BIT folder.
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 10-03-2014, 19:45   #111 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,345
Yes Confirm.
@amcti_gsm, Atf 11.60 must need of Uninstall first.
After that Install 11.70 Full version, extract the 2 DLL from OPEN SSL 32/64 BIT and copy/paste in C:\AdvanceBox Turbo Flasher\.
Why you have done IT?:
setup again 11.60 and copy pest 11.70 application with OPEN_SSL_32_BIT
WRONG!!! wey not is complicate make one easy copy/paste, if not are good for this....
The Following User Says Thank You to allumts For This Useful Post:
Old 10-04-2014, 08:19   #112 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
@All Windows 7 64bit Users:!
please use 32bit dll files no need to use 64 bit files.we apple team check and confirm,here is proof:
Old 10-11-2014, 15:36   #113 (permalink)
Member: 2236725
my skype is constantine0307 and i having seriuos problems with my atf box,please somebody find me on skype and help ,i would really be happy is someone could fix my problem relating with atf
Old 10-11-2014, 16:40   #114 (permalink)
allumts's Avatar
Member: 1564612
No need Skype, post here you problem, (post pictures, if cannot post upload and paste here Link for forum), or find by yourself solution in this thread.
allumts
Old 10-11-2014, 17:34   #115 (permalink)
Member: 2078045
Thanks Meter: 151
atf nitro no open ultimate version 11.70 no detect box ??
Old 10-11-2014, 19:47   #116 (permalink)
allumts's Avatar
Member: 1564612
Post what have done, error with photo and read a little this thread about .dll for you SO.
allumts
Old 10-13-2014, 07:49   #117 (permalink)
Fazil's Avatar
Member: 282757
Sonork: 100.1606418
Thanks Meter: 34
invalid response 11.70
Old 10-13-2014, 10:27   #118 (permalink)
Member: 651945
Next time use your eyes to read post #112
If you cannot understand post #112 here is another thread which tells you exactly the same thing.
http://forum.gsmhosting.com/vbb/f609...ponse-1864764/
If you still cannot understand that, try reading it 100 times.
Old 10-25-2014, 04:48   #119 (permalink)
muzammilrashdi's Avatar
Member: 2116947
Sonork: 100.1652193
Thanks Meter: 1,302
need help atf 11.70 activation problem
The Following User Says Thank You to muzammilrashdi For This Useful Post:
Old 10-27-2014, 14:21   #120 (permalink)
Member: 2115561
Atf problem invalid response v8.70
Page generated in 0.22272 seconds with 9 queries
