03-31-2012, 15:31 | #1 (permalink) |
Freak Poster Join Date: May 2008
Member: 778346 Status: Offline Thanks Meter: 34 | after update firmware bb5 bus check and scan not working - [SOLVED] bus check,scan,and flashing not working pls help here is bus check and reset box log Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done BootFlashModeDCT5Ex Failed Advance Turbo Flasher Found ================================================ Driver Version : 00020819 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 10.3.12 Software Version : v8.60 AdvanceBox SN : xxxxxxxxxxxxxxxxxxxx Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
03-31-2012, 16:02 | #2 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Contact me on messenger Br - srinibas (ATF Team ) |
The Following User Says Thank You to srinibas For This Useful Post: |
04-01-2012, 11:30 | #3 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @amit_deswal22 You wrote wrong frimware to your box. What did you select during update? Normal PCB or Modified PCB ? BR |
04-02-2012, 10:06 | #4 (permalink) |
Member: 778346 Status: Offline Thanks Meter: 34 | yes sir when i update first i update modified pcb.but after update exe got hang then i update firmware again but after update it ask again for update firmware at last i used restore box. now i try update firmware using modified pcb it always switch to normal pcb. what to do now pls help. i m not able to flash,check,scan any bb5 phone... |
04-03-2012, 09:48 | #5 (permalink) |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | I have solved the problem of Mr amit through team viewer . His fault was , he have update wrong firmware Br - srinibas ( ATF Team ) |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
