02-06-2016, 11:56 | #10 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 251872 Status: Offline Thanks Meter: 309 | Z3X EasyJtag Software ver. 2.0.7.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0505131CFE0B27E2, ,FW Ver.: 01.52 CMD Pullup Level:433 mV CMD Active Level:2031 mV HiPower™ mode is off! eMMC Device Information EMMC CID : 1101003430303037330065CAC403A2A2 EMMC CSD : D07E00320F5903FFFFFFFFE78A4000D0 EMMC Manufacturer ID: 0011 , OEM ID: 0100 EMMC Date: 10/2015 Rev.0x0 EMMC NAME: 400073 , S/N: 1707787267 EMMC NAME (HEX): 34303030373300 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.7 (MMC Unknown) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 Backup saved: 400073_1707787267_20160206_1411.extcsd Done. Z3X EasyJtag Software ver. 2.0.7.0 Skip loading eMMC Addon Firmware CMD Pullup Level:433 mV CMD Active Level:2031 mV Output file :\00989141520183\EMMC_ROM2_00000000_00400000.bin Reading 0x000000400000 bytes from 0x000000000000 ...ROM2 ( BOOT1 ROM) Done. Read Speed: 699 kB/s |
02-06-2016, 17:08 | #14 (permalink) |
Member: 251872 Status: Offline Thanks Meter: 309 | Total Elapsed Time 00:00:27 Write Success! Flash Image: PIT Start Writing 0x00000008 Blocks at 0x00000022 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: SGPT Start Writing 0x00000021 Blocks at 0x01D59FDF Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: sboot.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 1 Total Elapsed Time 00:00:07 Write Success! Flash Image: param.bin Start Writing 0x00004000 Blocks at 0x0001A800 Partition Selected: USER AREA Total Elapsed Time 00:00:13 Write Success! Flash Image: cm.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 1 Total Elapsed Time 00:00:07 Write Success! Total Images Written: 3 Process Done! |
The Following User Says Thank You to shahram11 For This Useful Post: |
02-06-2016, 17:08 | #15 (permalink) |
Member: 251872 Status: Offline Thanks Meter: 309 | ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 110100343030303733008A4B30E7A207 CSD : D07E00320F5903FFFFFFFFE78A4000D1 eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 4096 KB HC ERASE GROUP SIZE: 4096 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB eMMC Device Information Manufacturer ID: TOSHIBA Device Type : Embedded BGA Application ID : 00 Product Name : 400073 Product Rev : 0.0 Product SN : 8A4B30E7 Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 8000 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 110100343030303733008A4B30E7A207.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ |
The Following 3 Users Say Thank You to shahram11 For This Useful Post: |
