11-26-2014, 11:48 | #1 (permalink) |
Major Poster Join Date: Apr 2005 Age: 44
Member: 133116 Status: Offline Thanks Meter: 1 | Jtag boot error... Jtag boot repair failing.. Please help. WP_20141122_004-1.jpg Photo by sahshirshak | Photobucket |
11-26-2014, 13:01 | #3 (permalink) |
Member: 133116 Status: Offline Thanks Meter: 1 | Also i have problem that sometimes or rather most of the times it says "no devices found in the chain" http://i1260.photobucket.com/albums/.../jtagerror.png |
11-26-2014, 13:11 | #4 (permalink) |
Member: 133116 Status: Offline Thanks Meter: 1 | Please help.. Dear Sir, Now i m getting "memory write error, shift IR error" using rm-820 -- 920_RM-820_v2 file - 2044 kb and using bigboot file getting " CSR Write Failed" Default language ID 0x0409, LR 12 JTAG Interface Connected, S/N 0x8F489D4F Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...2 Device(s) Device #1 ID 0x4BA00477 IR4 Device #2 ID 0x706B40E1 IR11 Resetting and Exploring JTAG chain...2 Device(s) Device #1 ID 0x4BA00477 IR4 Device #2 ID 0x706B40E1 IR11 Loading AFP (Please Wait)...OK AFP revision 4, compiled 6/25/2014 11:26:00 PM ================================================== ======== Phone Type : Lumia 920 RM-820 CPU Type : Qualcomm MSM8960 Storage Type: eMMC 32GB Boot Package: 3051.40000.1347.1004 ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Restore Boot... Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...110100303332473934000A52B2EE8F04 Flash Description: Toshiba 032G94, 29.12 GiB, SN 0A52B2EE, Aug 2012 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Turbo JTAG Frequency 10.00 MHz! Sending Flash Loader...Memory Write Error, Shift IR Error(s) Task Process Saved to: LUMIA_920_RM-820_BIG_BOOT.task Restore Boot... Waiting for Device Connection 15 second(s)...User break! Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x4F1F0F0F IR4 Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x4F1F0F0F IR4 Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x4F1F0F0F IR4 Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x4F1F0F0F IR4 Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x4F1F0F0F IR4 Restore Boot... Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Restore Boot... Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x4F1F0F0F IR4 Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x4F1F0F0F IR4 Loading AFP (Please Wait)...OK AFP revision 1, compiled 8/27/2013 1:43:00 PM ================================================== ======== Phone Type : Lumia 920 RM-820 CPU Type : Qualcomm MSM8960 Storage TYpe: eMMC 32GB Boot Package: 1232.5962.1314.0002 ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Restore Boot... Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...110100303332473934000A52B2EE8F04 Flash Description: Toshiba 032G94, 29.12 GiB, SN 0A52B2EE, Aug 2012 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Turbo JTAG Frequency 10.00 MHz! Sending Flash Loader...Memory Write Error, Shift IR Error(s) |
