Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 04-18-2011, 15:15   #1 (permalink)
Member: 3890
C7 reading hash problem UFC GPG
hello, i am using ufc gpg cable for not open phone, with cable 6 pines read info ok, but for hash vbat problem, is impposible read hash, anybody tested with ufc cables ?
Old 04-18-2011, 15:19   #2 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
@ChavaL
ATF Big or ATF Lightning?
Check your BSI pin.
Post logs is better
Old 04-18-2011, 15:22   #3 (permalink)
Member: 3890
ATF Lightning...
All pines is ok, i tested with charge nokia, tested all V 2,5..., always the same problem.
Old 04-18-2011, 15:37   #4 (permalink)
Member: 651945
@ChavaL
Try this,, do not connect the BATTERY GND PIN (MIDDLE PIN).
Cover the BATTER middle contact on phone so that it will not come in contact
with the Cable.
Then try buscheck and post logs here.
B.R.
Old 04-19-2011, 11:41   #5 (permalink)
Member: 973412
Thanks Meter: 117
bro see this log
20:17:15 : MCU: V 92PS1_10w36.2 14-09-10 RM-675 (c) Nokia
20:17:15 : IMEI: 353755043139411
20:17:15 : Model : Nokia C7-00
20:17:16 : Product Serial Number: CJP035896
20:17:16 : Product Code : 059D0B0
20:17:16 : Module Code : 0204505
20:17:16 : Basic Production Code: 0591401
20:17:24 : HW Version : 6003
20:17:25 : RFIC Version : |Alli_4.3.4
20:17:25 : DSP Version : TB92PS1_10w36
20:17:25 : APE BT Version : HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13.
20:17:25 : AHNE Version : 11
20:17:26 : APE SW Core Version : 012.003
20:17:26 : APE Variant Version : 012.003.00.01012.003.11.01012.003.206.03
20:17:26 : APE Test Version : rm675_ENO_v_0.0308_ORFS_TRI
20:17:27 : Retu Version : 40
20:17:27 : Tahvo Version : 00
20:17:27 : APE HW Version : 256
20:17:27 : APE ADSP SW Version : 256
20:17:27 :
20:17:27 : ******** Reading SimLock ********
20:17:27 : CONFIG KEY: 0000000000000000
20:17:27 : PROVIDER KEY: 2140100000000000
20:17:27 : Provider : Vodafone / Airtel Movil;Spain
20:17:27 : Counters : 0/3 , 0/10
20:17:27 : Block [1] 1:Close
20:17:27 : Block [2] 1:Close
20:17:27 : SP Lock Status : Locked
20:17:27 :
20:17:28 : SIMLOCK_TYPE : PA_SL3 (15-digit NCK)
20:17:28 : SIMLOCK_TEST : PASSED
20:17:28 : SECURITY_TEST : PASSED
20:17:29 : PHONE_MODE : LOCAL MODE
20:17:29 :
20:17:39 :
20:17:39 : AdvanceBox SendBootCodeEx
20:17:39 : InitialiseBootstrap_DCT5 DIR
20:17:39 : BootFlashMode_DCT5
20:17:39 :
20:17:39 : ************************************************** ****
20:17:39 : TIME STARTS HERE
20:17:39 :
20:17:39 : BootFlashModeDCT5Ex Succeeded First Time
20:17:39 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
20:17:39 : Number of Sub Blocks 7 (0x07)
20:17:39 : 1 SYSTEM_ASIC_ID 01
20:17:39 : Block Length : 21 (15)
20:17:39 : BB ASIC Index : 0 (00) CMT
20:17:39 : ID DWORD 0 : 00000003
20:17:39 : ID DWORD 1 : 00000226
20:17:39 : ID DWORD 2 : 00010007
20:17:39 : ID DWORD 3 : 600C1921
20:17:39 : ID DWORD 4 : 02031104
20:17:39 : 2 ROM_ID 15
20:17:39 : Block Length : 5 (05)
20:17:39 : ID DWORD 0 : 00001040
20:17:39 : 3 ROM_ID 15
20:17:39 : ID DWORD 0 : 00001030
20:17:39 : 4 PUBLIC_ID 12
20:17:39 : ID DWORD 0 : 28B00111
20:17:39 : ID DWORD 1 : BF0B0049
20:17:39 : ID DWORD 2 : B9C0AF69
20:17:39 : ID DWORD 3 : 76C6DE32
20:17:39 : ID DWORD 4 : 10CC5B64
20:17:39 : 5 ASIC_MODE_ID 13
20:17:39 : Block Length : 2 (02)
20:17:39 : Mode Id : 00
20:17:39 : 6 ROOT_KEY_HASH 14
20:17:39 : Block Length : 17 (11)
20:17:39 : Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B
20:17:39 : 7 ROM_ID 15
20:17:39 : Block Length : 9 (09)
20:17:39 : CRC 0 : E693EF0D
20:17:39 : CRC 1 : AC22615B
20:17:39 : Checksum C6
20:17:39 :
20:17:39 : SearchForBootstrap_DCT5..
20:17:39 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg
20:17:39 : Boot File - Version 010.050.00
20:17:39 : Boot File - Revision 0x0003 (3)
20:17:39 : eBB5ProtocolType == New
20:17:39 : PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
20:17:39 : PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
20:17:39 : SearchForBootstrap_DCT5 : No Error - 0 (0x00)
20:17:39 : Secondary Loader Sent...
20:17:39 : TransmissionTypeRequest_DCT5_NewProtocol
20:17:39 : TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
20:17:39 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
20:17:40 : TransmissionTypeRequest_DCT5_NewProtocol
20:17:40 : FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
20:17:40 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
20:17:40 : Transmission Type Request Sent...
20:17:40 : ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
20:17:40 : MCU_CONFIGURATION_RESPONSE_BB5:
20:17:40 : MessageID : 06
20:17:40 : SubBlocks : 06
20:17:40 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
20:17:40 : Block Length : 0B
20:17:40 : BB ASIC Index : CMT 00
20:17:40 : Device Type : RAM 05
20:17:40 : Device Index : 00
20:17:40 : Manufacturer Code : 0000 -> Flash
20:17:40 : Device ID : 0000 -> not detected
20:17:40 : Extended/Fixed ID : 0000
20:17:40 : Revision ID : 0000
20:17:40 : 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
20:17:40 : Device Type : MMC 04
20:17:40 : Manufacturer Code : FFFF -> Flash
20:17:40 : Device ID : 0000 -> BAD FLASH TYPE
20:17:40 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
20:17:40 : Device Type : NOR 00
20:17:40 : 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
20:17:40 : Device Index : 01
20:17:40 : Manufacturer Code : 0000 -> SPANSION
20:17:40 : Device ID : 0001 -> not used
20:17:40 : 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
20:17:40 : Device Type : MuxOneNAND 03
20:17:40 : Manufacturer Code : 00EC ->
20:17:40 : Device ID : 0068 -> Type not in database
20:17:40 : Revision ID : 0131
20:17:40 : 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
20:17:40 : Block Length : 09
20:17:40 : Data : XSR 1.6
20:17:40 : Checksum : F0
20:17:40 : SearchForBootstrap_DCT5 : No Error - 0 (0x00)
20:17:40 : FLS1SendAlgoCodeEx..
20:17:40 : SendAlgoCode_DCT5..
20:17:40 : SearchForAlgorithm_DCT5..
20:17:40 : Looking for ALL Devices...
20:17:40 : Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0068 ExtID :0000 RevID :0131
20:17:40 : Flash Descriptor
20:17:40 : Size : 40000000 (1024 MB)
20:17:40 : VPP Info : 0000
20:17:40 : Erase10s : 1E
20:17:40 : Block1s : 32
20:17:40 : BErase1s : 02
20:17:40 : Reserved0 : 00
20:17:40 : Reserved1 : 00
20:17:40 : Reserved2 : 00
20:17:40 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg
20:17:40 : Algorithm File - Version 010.050.00
20:17:40 : Algorithm File - Revision 0x0003 (3)
20:17:40 : eBB5ProtocolType == New
20:17:41 : Patch Loader Found!
20:17:41 : C:\AdvanceBox Turbo Flasher\Nokia\loader\CustomLoader_RAPUv11.ldr
20:17:42 : Algo Loader Sent...
20:17:42 : SendCodeStart_NewProtocol :
20:17:47 : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
20:17:47 : TransmissionTypeRequest_DCT5_NewProtocol
20:17:47 : TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
20:17:47 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
20:17:48 : TransmissionTypeRequest_DCT5_NewProtocol
20:17:48 : FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
20:17:48 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
20:17:48 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
20:17:48 : FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
20:17:48 : FUR control Ok...
20:17:48 : VPP Enabled by Software
20:17:48 : Using Internal VPP
20:17:48 : FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
20:17:48 : Pabub KEY Request
20:17:48 : PhoneInfoRequest_BB5 (Asic Index 00 )
20:17:48 : PHONE_INFO_RESPONSE_BB5
20:17:48 : PAPUB_KEYS_HASH_RESP_BB5 2A
20:17:48 : BB Asic Index : 00
20:17:48 : CMT PAPUBKEYS HASH:
20:17:48 : 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F
20:17:49 : Reading NPC IMEI...
20:17:49 : 353755043139411
20:17:49 : Connecting to The ATF Network
20:17:51 : Network Connection Accepted
20:17:51 : Requesting Authorization Code
20:17:53 : Authorization Code Received
20:17:54 : Verifying Authorization Code
20:17:54 : Authorization Code is OK
20:17:54 : Saving Authorization Code
20:17:56 : File Saving Complete!!!
20:17:56 :
20:17:56 :
20:17:56 : ================================================== ====
20:17:56 : Phone was Successfully Authorized
20:17:56 : Super Dongle Repair and Stand Alone SX-4
20:17:56 : is NOW ENABLED for this Phone...
20:17:56 :
20:17:56 : Thank you for using The ATF Network
20:17:56 :
20:17:56 :
20:17:56 : FlashInfo.RestartMode : 2
20:17:56 :
20:17:56 : Time Taken to Complete Tasks: 00:00:18
20:18:22 :
20:18:22 : MCU: V 92PS1_10w36.2 14-09-10 RM-675 (c) Nokia
20:18:22 : IMEI: 353755043139411
20:18:22 : Model : Nokia C7-00
20:18:22 : Product Serial Number: CJP035896
20:18:22 : Product Code : 059D0B0
20:18:23 : Module Code : 0204505
20:18:23 : Basic Production Code: 0591401
20:18:23 : Default SN Type : 0
20:18:25 : PPM Version : V 92PS1_10w36.2 14-09-10 RM-675 (c) Nokia
20:18:25 : HW Version : 6003
20:18:25 : RFIC Version : |Alli_4.3.4
20:18:25 : DSP Version : TB92PS1_10w36
20:18:26 : APE BT Version : HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13.
20:18:26 : AHNE Version : 11
20:18:27 : APE SW Core Version : 012.003
20:18:27 : APE Variant Version : 012.003.00.01012.003.11.01012.003.206.03
20:18:27 : APE Test Version : rm675_ENO_v_0.0308_ORFS_TRI
20:18:27 : Retu Version : 40
20:18:27 : Tahvo Version : 00
20:18:28 : APE HW Version : 256
20:18:28 : APE ADSP SW Version : 256
20:18:28 :
20:18:28 : ******** Reading SimLock ********
20:18:28 : CONFIG KEY: 0000000000000000
20:18:28 : PROVIDER KEY: 2140100000000000
20:18:28 : Provider : Vodafone / Airtel Movil;Spain
20:18:28 : Counters : 0/3 , 0/10
20:18:28 : Block [1] 1:Close
20:18:28 : Block [2] 1:Close
20:18:28 : SP Lock Status : Locked
20:18:28 :
20:18:28 : SIMLOCK_TYPE : PA_SL3 (15-digit NCK)
20:18:29 : SIMLOCK_TEST : PASSED
20:18:29 : SECURITY_TEST : PASSED
20:18:29 : PHONE_MODE : TEST MODE
20:18:29 :
20:18:31 :
20:18:31 : AdvanceBox SendBootCodeEx
20:18:31 : InitialiseBootstrap_DCT5 DIR
20:18:31 : BootFlashMode_DCT5
20:18:31 :
20:18:31 : ************************************************** ****
20:18:31 : TIME STARTS HERE
20:18:31 :
20:18:31 : BootFlashModeDCT5Ex Succeeded First Time
20:18:31 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
20:18:31 : Number of Sub Blocks 7 (0x07)
20:18:31 : 1 SYSTEM_ASIC_ID 01
20:18:31 : Block Length : 21 (15)
20:18:31 : BB ASIC Index : 0 (00) CMT
20:18:31 : ID DWORD 0 : 00000003
20:18:31 : ID DWORD 1 : 00000226
20:18:31 : ID DWORD 2 : 00010007
20:18:31 : ID DWORD 3 : 600C1921
20:18:31 : ID DWORD 4 : 02031104
20:18:31 : 2 ROM_ID 15
20:18:31 : Block Length : 5 (05)
20:18:31 : ID DWORD 0 : 00001040
20:18:31 : 3 ROM_ID 15
20:18:31 : ID DWORD 0 : 00001030
20:18:31 : 4 PUBLIC_ID 12
20:18:31 : ID DWORD 0 : 28B00111
20:18:31 : ID DWORD 1 : BF0B0049
20:18:31 : ID DWORD 2 : B9C0AF69
20:18:31 : ID DWORD 3 : 76C6DE32
20:18:31 : ID DWORD 4 : 10CC5B64
20:18:31 : 5 ASIC_MODE_ID 13
20:18:31 : Block Length : 2 (02)
20:18:31 : Mode Id : 00
20:18:31 : 6 ROOT_KEY_HASH 14
20:18:31 : Block Length : 17 (11)
20:18:31 : Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B
20:18:31 : 7 ROM_ID 15
20:18:31 : Block Length : 9 (09)
20:18:31 : CRC 0 : E693EF0D
20:18:31 : CRC 1 : AC22615B
20:18:31 : Checksum C6
20:18:31 :
20:18:31 : SearchForBootstrap_DCT5..
20:18:31 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg
20:18:31 : Boot File - Version 010.050.00
20:18:31 : Boot File - Revision 0x0003 (3)
20:18:31 : eBB5ProtocolType == New
20:18:31 : PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
20:18:31 : PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
20:18:31 : SearchForBootstrap_DCT5 : No Error - 0 (0x00)
20:18:32 : Secondary Loader Sent...
20:18:32 : TransmissionTypeRequest_DCT5_NewProtocol
20:18:32 : TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
20:18:32 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
20:18:33 : TransmissionTypeRequest_DCT5_NewProtocol
20:18:33 : FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
20:18:33 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
20:18:33 : Transmission Type Request Sent...
20:18:33 : ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
20:18:33 : MCU_CONFIGURATION_RESPONSE_BB5:
20:18:33 : MessageID : 06
20:18:33 : SubBlocks : 06
20:18:33 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
20:18:33 : Block Length : 0B
20:18:33 : BB ASIC Index : CMT 00
20:18:33 : Device Type : RAM 05
20:18:33 : Device Index : 00
20:18:33 : Manufacturer Code : 0000 -> Flash
20:18:33 : Device ID : 0000 -> not detected
20:18:33 : Extended/Fixed ID : 0000
20:18:33 : Revision ID : 0000
20:18:33 : 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
20:18:33 : Device Type : MMC 04
20:18:33 : Manufacturer Code : FFFF -> Flash
20:18:33 : Device ID : 0000 -> BAD FLASH TYPE
20:18:33 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
20:18:33 : Device Type : NOR 00
20:18:33 : 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
20:18:33 : Device Index : 01
20:18:33 : Manufacturer Code : 0000 -> SPANSION
20:18:33 : Device ID : 0001 -> not used
20:18:33 : 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
20:18:33 : Device Type : MuxOneNAND 03
20:18:33 : Manufacturer Code : 00EC ->
20:18:33 : Device ID : 0068 -> Type not in database
20:18:33 : Revision ID : 0131
20:18:33 : 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
20:18:33 : Block Length : 09
20:18:33 : Data : XSR 1.6
20:18:33 : Checksum : F0
20:18:33 : SearchForBootstrap_DCT5 : No Error - 0 (0x00)
20:18:33 : FLS1SendAlgoCodeEx..
20:18:33 : SendAlgoCode_DCT5..
20:18:33 : SearchForAlgorithm_DCT5..
20:18:33 : Looking for ALL Devices...
20:18:33 : Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0068 ExtID :0000 RevID :0131
20:18:33 : Flash Descriptor
20:18:33 : Size : 40000000 (1024 MB)
20:18:33 : VPP Info : 0000
20:18:33 : Erase10s : 1E
20:18:33 : Block1s : 32
20:18:33 : BErase1s : 02
20:18:33 : Reserved0 : 00
20:18:33 : Reserved1 : 00
20:18:33 : Reserved2 : 00
20:18:33 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg
20:18:33 : Algorithm File - Version 010.050.00
20:18:33 : Algorithm File - Revision 0x0003 (3)
20:18:33 : eBB5ProtocolType == New
20:18:34 : Algo Loader Sent...
20:18:34 : SendCodeStart_NewProtocol :
20:18:34 : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
20:18:34 : TransmissionTypeRequest_DCT5_NewProtocol
20:18:34 : TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
20:18:34 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
20:18:34 : FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
20:18:34 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
20:18:35 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
20:18:35 : FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
20:18:35 : FUR control Ok...
20:18:35 : VPP Enabled by Software
20:18:35 : Using Internal VPP
20:18:35 : FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
20:18:35 : Pabub KEY Request
20:18:36 : PhoneInfoRequest_BB5 (Asic Index 00 )
20:18:36 : PHONE_INFO_RESPONSE_BB5
20:18:36 : PAPUB_KEYS_HASH_RESP_BB5 2A
20:18:36 : BB Asic Index : 00
20:18:36 : CMT PAPUBKEYS HASH:
20:18:36 : 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F
20:18:36 :
20:18:36 : Scanning Simlock Applet Type...
20:18:40 : OK
20:18:40 :
20:18:40 : =================================================
20:18:40 : PA_SL3 Applet detected
20:18:40 :
20:18:40 : Dumping RSA Modulus...
20:18:40 : OK
20:18:40 :
20:18:40 : RSA Modulus OK
20:18:40 : FlashInfo.RestartMode : 2
20:18:41 :
20:18:41 : ================================================== =
20:18:41 : Decrypt SL3 PM 120 HASHES for Brute Force Unlock
20:18:41 : Decrypting PM 120...
20:18:41 : (This may take upto 30 Seconds on New RAPIDO HASH)
20:18:41 :
20:18:41 : PM 120 HASHES Extracted Successfully
20:18:41 :
20:18:41 : F39E2B5130249A9905BD8BF2B10F26A7C4F408D0
20:18:41 : 239BDF417B2E240F2BCF76E4015B30CED3D1BD69
20:18:41 : 3C8C0B4D3B904193BF8A5D2ABE98C63635B6020C
20:18:41 : 8815F60D3FCF0C67249A4CE4A29060F96AFECF81
20:18:41 : 74706890AA4DCF7A833C54C9E174B5F3A156C452
20:18:41 : 0DF321665D8E60828B02243E14D22EA199F28F69
20:18:41 : 7F32E2AE912332144FC201FC665245D97F74F883
20:18:41 : E31107F2DEC3840E11C9F767895D5B53FA1A5F2F
20:18:41 :
20:18:41 :
20:18:41 :
20:18:41 : Log Files for Local Brute Force Saved to:
20:18:41 : C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\353755043139411\353755043 139411.log
20:18:41 : C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\353755043139411\353755043 139411.bcl
20:18:41 : C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\353755043139411\353755043 139411.sha
20:18:41 :
20:18:41 : Command Line for ighashgpu:
20:18:41 : ighashgpu -t:sha1 -salt:003537550431394100 -h:F39E2B5130249A9905BD8BF2B10F26A7C4F408D0 -uh:00010203040506070809 -min:15 -max:15
20:18:41 :
20:18:41 : Saved as MS Batch File: 353755043139411_ighashgpu.bat
20:18:41 :
20:18:41 : Process Done!
Model : Nokia C7-00
HW Version : 6003
AHNE Version : 11
Retu Version : 40
Tahvo Version : 00
Block [1] 1:Open
Block [2] 1:Open
SP Lock Status : Not Locked
Old 04-20-2011, 14:19   #6 (permalink)
Member: 3890
re
VBATT OFF...
VBATT ON
Setting VBATT Done!...
VBATT OFF...
VBATT ON
VBATT OFF...
VBATT ON
BootFlashModeDCT5Ex Failed
IMEI: 355379x
Model : Nokia C7-00
Product Serial Number: CKO812367
Default SN Type : 0
HW Version : 6010
AHNE Version : 11
Retu Version : 40
Tahvo Version : 00
Block [1] 1:Close
Block [2] 1:Close
Changing MODE : FLASH
VBATT OFF...
VBATT ON
VBATT OFF...
VBATT ON
VBATT OFF...
VBATT ON
IMEI: 355379047236277
Model : Nokia C7-00
Default SN Type : 0
HW Version : 6010
AHNE Version : 11
Retu Version : 40
Tahvo Version : 00
Block [1] 1:Close
Block [2] 1:Close
VBATT OFF...
VBATT ON
VBATT OFF...
VBATT ON
VBATT OFF...
VBATT ON
IMEI: 3553790x
Model : Nokia C7-00
Default SN Type : 0
HW Version : 6010
AHNE Version : 11
Retu Version : 40
Tahvo Version : 00
Block [1] 1:Close
Block [2] 1:Close
VBATT OFF...
VBATT ON
VBATT OFF...
VBATT ON
VBATT OFF...
VBATT ON
IMEI: 35537904x
Model : Nokia C7-00
Default SN Type : 0
HW Version : 6010
AHNE Version : 11
Retu Version : 40
Tahvo Version : 00
Block [1] 1:Close
Block [2] 1:Close
VBATT OFF...
VBATT ON
VBATT OFF...
VBATT ON
VBATT OFF...
VBATT ON
Old 04-20-2011, 16:53   #7 (permalink)
Member: 973412
Thanks Meter: 117
bro check cable and try again
Old 04-26-2011, 15:22   #8 (permalink)
Member: 3890
i cheked cable and i have other set ufc, same problem. Other pc same problemmm... sure UFC can read hash without open phone ????
Old 04-26-2011, 15:39   #9 (permalink)
himanshu taldar's Avatar
Member: 422762
Sonork: 100.1593904
Thanks Meter: 973
try with good FBUS cable, not UFC
Old 04-26-2011, 15:42   #10 (permalink)
Member: 3890
yes, opening the phone and fbus cable work, by my question is if ufc is supported for read hash ???
Old 04-26-2011, 16:01   #11 (permalink)
Member: 886190
Sonork: 12345678
Thanks Meter: 30
6120 power on then off i try it flash and write blank ppm but same
atf team pls help
ATF Software Version v7.40
ATF Lightning FBUS Flash Started...
Number of Image Files: 3
MCU: V 07.20 05-10-09 RM-243 (c) Nokia
IMEI: 359849015532879
Model : Nokia 6120
Product Serial Number: MXG744564
Product Code : 0552203
Basic Production Code: 0539292
Default SN Type : 0
PPM Version : V 07.20 05-10-09 RM-243 (c) Nokia
HW Version : 0602
RFIC Version : 17141715
DSP Version : 06w41pb_08w28.0.3_rm243
AHNE Version : 11
APE SW Core Version : 07.20
APE Variant Version : rofs_version_inforofx_version_info
APE Test Version : rm243_ENO_A_2009wk15v0.100
Retu Version : 15
Tahvo Version : 22
PROVIDER KEY: 2440700000000000
Provider : AT&T;U.S.A. (3650)
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK_TYPE : PA_SL1/PA_SL2
SECURITY_CODE : 12345
PM 120 Found...
PM 308 Found...
SimLock Certificate Saved to : C:\AdvanceBox Turbo Flasher\Nokia\Backup\359849015532879\SL2_certifica te_V 07.20 05-10-09 RM-243 (c) Nokia_359849015532879_Not Locked_74845.pm
BootFlashMode_DCT5
TIME STARTS HERE
1 SYSTEM_ASIC_ID 01
ID DWORD 0 : 00000001
ID DWORD 2 : 00010006
ID DWORD 3 : 400C1921
ID DWORD 4 : 01021103
2 ROM_ID 15
ID DWORD 0 : 00000295
3 ROM_ID 15
ID DWORD 0 : 00000B22
4 PUBLIC_ID 12
ID DWORD 0 : 1F800115
ID DWORD 1 : AD8A0058
ID DWORD 2 : DC9AF560
ID DWORD 3 : B7489B59
ID DWORD 4 : 12B430B7
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE
7 ROM_ID 15
CRC 0 : A8C1D671
CRC 1 : 3E691FF8
Checksum D3
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg
Boot File - Revision 0x0002 (2)
MessageID : 06
SubBlocks : 06
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Manufacturer Code : 0400 -> Flash
Device ID : 0000 -> Type not in database
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Device ID : 0030 -> K5W1G13ACB
Revision ID : 0221
Block Length : 09
Data : XSR 1.5
Checksum : 34
SendAlgoCode_DCT5..
Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0030 ExtID :0000 RevID :0221
Flash Descriptor
Device ID : 0030
Revision ID : 0000
Size : 08000000 (128 MB)
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.f g
Algorithm File - Revision 0x0002 (2)
Algo Loader Sent...
FUR control Ok...
Using Internal VPP
Pabub KEY Request
BB Asic Index : 00
CMT PAPUBKEYS HASH:
0FE1BA92D924A658E4800780FA6F4868100AC947
START READING RPL DATA
Reading : NPC (CMT)
OK
Reading : VARIANT (CMT)
VARIANT : Empty
Reading : CCC (CMT)
OK
Reading : HWC (CMT)
OK
Reading : R&D (CMT)
OK
FINISHED READING RPL DATA
RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\359849015532879\3598490155328 79_74855.rpl
Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-243\rm243_05.11_prd_core.fpsx
CMT Type : BB5
CMT Algorithm : XSR 1.5
Secondary Sending Speed : 650000Hz
Algorithm Sending Speed : 13000000Hz
Program Sending Speed : 13000000Hz
Message Reading Speed : 98000Hz
Number of Blocks : 385
Entry Point: 0x1E948E
Page Format : -1
MAX PAGE : 0x00020000
CMT Type : BB5
Page Format : -1
VBATT OFF...
VBATT ON
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded after 3 Attempts
1 SYSTEM_ASIC_ID 01
2 ROM_ID 15
3 ROM_ID 15
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : A8C1D671
CRC 1 : 3E691FF8
Checksum D3
MessageID : 06
SubBlocks : 06
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0221
Block Length : 09
Data : XSR 1.5
Checksum : 34
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 0030
Revision ID : 0000
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
Algo Loader Sent...
FUR control Ok...
Using Internal VPP
Pabub KEY Request
BB Asic Index : 00
CMT PAPUBKEYS HASH:
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
Partition Blocks : 1
1 PARTITION_INFO_BB5
BB ASIC Index : 0x00 CMT
Device Type : 0x03 MuxOneNAND
Device Index : 0x00
Partition Version : 00010000
Spare : FFFFFFFF
Num Partitions : 00000004
Partition 1
Attribute : 00000002 RO
Start Address : 00080000
Partition 2
ID : 00000004 DEMANDONOS
Start Address : 01500000
Partition 3
ID : 00000008 FILESYSTEM
Attribute : 00000001 RW
Start Address : 04E00000
Partition 4
Start Address : 07B40000
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 00020008000001480000000000040000000201500000039000 00000000080000000104E0000002D400000000000A00000001 07B40000001600009D
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength : 0x4F (79)
ERASE Blocks : 0x02 (2)
0 ERASE_AREA_BB5 0x12
Block Length : 0x1B (27)
Device Index : 0x00
0 : 00040000-00082FFF
1 : 00083400-0087FFFF
2 : 00B80000-04DFFFFF
1 FORMAT_PARTITION_BB5 0x19
Block Length : 0x2F (47)
Device Index : 0x00
Format Info ID : 0x00000000
Format Info : 000000000000000A0000000000000002000000640000000300 000001000000010000000000000000
Erase_SendEraseBlock_BB5_NOR
Task in Progress... Please Wait...
Erase_SendFormatPartition_BB5_NOR
Successfully erased..
Time Taken to Erase : 00:00:01
Flashing Speed: 5.00 Mhz (AUTO)
Processing : rm243_05.11_prd_core.fpsx
Total blocks to write : 385
>> CMT Rootkey Hash CERT : ADA
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : RAP3NAND
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS
>> CMT Rootkey Hash CERT : SOS*UPDAPP
>> CMT Rootkey Hash CERT : SOS*DSP0
>> CMT Rootkey Hash CERT : SOS*ISASW
>> CMT Rootkey Hash CERT : SOS*CORE
>> CMT Rootkey Hash CERT : SOS+ROFS
ContinueFlash_DCT5 Complete
Continue Flash Complete : : No Error - 0 (0x00)
Time Taken to Flash : 00:00:28
Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-243\rm243_05.11_prd_vB20_01_mea_a.fpsx
CMT Type : BB5
Number of Blocks : 133
Entry Point: 0x011A
Page Format : -1
CMT Type : BB5
Entry Point: 0x011A
Page Format : -1
No partition info....
StartErase_DCT5...
BlockLength : 0x0E (14)
ERASE Blocks : 0x01 (1)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 03300000-04DFFFFF
Time Taken to Erase : 00:00:00
Processing : rm243_05.11_prd_vB20_01_mea_a.fpsx
Total blocks to write : 133
>> CMT Rootkey Hash CERT : SOS+ROFX
Time Taken to Flash : 00:00:11
Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-243\rm243_05.11_prd_UDA_Classic_Blue.fpsx
CMT Type : BB5
Entry Point: 0x00F4
Page Format : -1
MAX PAGE : 0x0001BC00
CMT Type : BB5
Entry Point: 0x00F4
Page Format : -1
StartErase_DCT5...
Device Index : 0x00
0 : 04E00000-07B3FFFF
Processing : rm243_05.11_prd_UDA_Classic_Blue.fpsx
Time Taken to Flash : 00:00:00
Total Flash Write Time (Flashing Only) : 00:00:40
Total Flashing Time (Booting + Erase + Flashing) : 00:00:43
Status_BB5 STATUS_REQUEST_BB5..
1 Sub Block ID : 15 STATUS_NAND_OK_BB5
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Num Bad Blocks : 00000000
Additional Bad : 00000000
Correctable ECC : 00000000
Waiting for Phone to Go Online...
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
MCU: V 05.11 21-04-08 RM-243 (c) Nokia
Model : Nokia 6120
Default SN Type : 0
PPM Version : V 05.11 21-04-08 RM-243 (c) Nokia
HW Version : 0602
DSP Version : 06w41pb_08w08.0.1_rm243
AHNE Version : 11
APE SW Core Version : 05.11
Retu Version : 15
Tahvo Version : 22
Unable to read SP Data..
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
Model : Nokia 6120
Default SN Type : 0
HW Version : 0602
AHNE Version : 11
Retu Version : 15
Tahvo Version : 22
Model : Nokia 6120
Default SN Type : 0
HW Version : 0602
AHNE Version : 11
Retu Version : 15
Tahvo Version : 22
Model : Nokia 6120
Default SN Type : 0
HW Version : 0602
AHNE Version : 11
Retu Version : 15
Tahvo Version : 22
SL1/SL2 Simlock RPL Stand Alone Edition
Generating Simlock Dongle RPL...
-> OK: Simlock RPL accepted
VBATT OFF...
VBATT ON
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
Model : Nokia 6120
Default SN Type : 0
HW Version : 0602
AHNE Version : 11
Retu Version : 15
Tahvo Version : 22
SUPER_DONGLE_TEST : FAILED
> Try "Repair Super Dongle"
SL1/SL2 Phone detected
Successfully done.
Model : Nokia 6120
Default SN Type : 0
HW Version : 0602
AHNE Version : 11
Retu Version : 15
Tahvo Version : 22
Super Dongle RPL Stand Alone Edition
Generating Super Dongle RPL...
Sending Superdongle RPL...
OK: Super Dongle RPL accepted
Successfully done.
Model : Nokia 6120
Default SN Type : 0
HW Version : 0602
AHNE Version : 11
Retu Version : 15
Tahvo Version : 22
SUPER_DONGLE_TEST : PASSED
pls help how to solved this phone
Eeprom reading KLImax Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 09-22-2011 15:55
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 15:21
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.40734 seconds with 9 queries
