02-19-2013, 12:23 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Sharjah Age: 42
Member: 1158126 Status: Offline Sonork: 100.1589521 Thanks Meter: 475 | LBF Problem TIA Uploaded with ImageShack.us |
02-19-2013, 14:19 | #2 (permalink) |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | oclhashcat-lite from v14 not support SL3 algo then you need use older version like v10 to can work with SL3 algo. Atom live sl3 market becosue someone from gsm field crack v0.9 oclhashcat-lite. You will not see anymore new oclhashcat-lite that support SL3 algo. |
The Following User Says Thank You to wgmmmx1 For This Useful Post: |
02-19-2013, 15:45 | #3 (permalink) | |
Member: 1158126 Status: Offline Sonork: 100.1589521 Thanks Meter: 475 | Quote:
But where can i get this V0.10 or 0.9 as it is not available on hashcat site BR | |
02-19-2013, 22:54 | #4 (permalink) | |
No Life Poster Join Date: Jun 2009 Location: SouthAmericaUnlockers Age: 52
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | Quote:
Here Download oclhashcat-lite-0.09 - Download - 4shared If the link show error, browse mi 4shared 4shared - My 4shared - shared folder - free file sharing and storage remember date back to 2011 Br Polaco | |
02-20-2013, 01:45 | #7 (permalink) | |
Confuse...Unlock.Mk you say v13 no more support sl3! el - Download - 4shared regards polaco | |
02-20-2013, 02:09 | #8 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Macedonia
Member: 1671934 Status: Offline Thanks Meter: 247 | Quote: The version V0.13 been released on new year's eve while the issue with the patch happened on new year's day around 1PM so, until not been modded the zip file on the robot (But doesn't look like as the zip date states 31.12.2012) the support for the -m 1900 is still there. (-m 1900 means that SL3 support is still there in this version) As well the kernels m1900 are missing in the zip file since the version 0.10 which means it should relay on the old kernels anyway (or compile them when needed) Drivers that u need to use are Catalyst v12.8 Exact, no other version. Please uninstall driver u have, install Catalyst v12.8 and please , please try to unlock one phone, you will see that works. I am unlocking with my personal super computer Nokia Sl3 with Catalyst v12.8 installed and oclhashcat-lite-0.13. and never failed. Speed is great. If i am right, after trying, please press thanks. I do not need excuses. If you need proof, you got it, what do you need, just tell me. In the meantime please DOWNLOAD v0.13 and start unlocking | |
03-04-2013, 20:26 | #9 (permalink) |
Member: 1671934 Status: Offline Thanks Meter: 247 | V0.13 of oclhashcat-lite works This is proof for everyone in this thread, or i can also say in this forum that use patched version oclhashcat-lite-0.09. Proof that shows how v0.13 works perfect in unlocking SL3 phones. If you can not make it to work, probably you do not read enough so if you want it on a silver plate, i am here to help you. Look at attachment very carefully and you will noticed not just that that v0.13 works but something that is in conjuction with my posts above. |
03-06-2013, 10:20 | #10 (permalink) | |
Code: ================================================ Basic Phone Information ================================================ MCU Version: V 09.10 25-08-09 RM-443 (c) Nokia IMEI Plain : 358005036773122 IMEI Spare : A358005036773120 IMEI SV : 33580050367731226F Phone Model: Nokia 6303 classic Category : Classic Phone Phone Type : RM-443 ================================================ Extended Phone Information ================================================ Product Serial Number: KKU276286 Product Code : 0587454 Module Code : 0204282 Basic Production Code: 0575069 Long Production SN : 0 PPM SW Version : V 09.10 25-08-09 RM-443 (c) Nokia D MCU SW Version : V 09.10 25-08-09 RM-443 (c) Nokia HW Version : 2002 RFIC Version : 0831 DSP Version : ICPR81_09w10_pre LCD Version : SEIKO Content Pack Version : Content: d_matt_black T-MOBILE MK 25-08-09 RM-443 (c) Nokia AHNE Version : 30 RETU Version : 15 TAHVO Version : 22 Bluetooth ID : A8:7E:33:17:3D:48 CS Type : GSM900, GSM1800, GSM1900 ================================================ Simlock Information ================================================ CONFIG KEY : 8000000000000000 PROVIDER KEY : 2940100016517386 NETWORK NAME : T-Mobile ;Macedonia [GSM] LOCK COUNTERS : KEYPRESS 3/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Close SIMLOCK STATE : LOCKED SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST Sending SP code: #pw+783256553761657+7# Sending FBUS Command FBUS Command Sent OK: code accepted ================================================ Basic Phone Information ================================================ MCU Version: V 09.10 25-08-09 RM-443 (c) Nokia IMEI Plain : 358005036773122 IMEI Spare : A358005036773120 IMEI SV : 33580050367731226F Phone Model: Nokia 6303 classic Category : Classic Phone Phone Type : RM-443 ================================================ Extended Phone Information ================================================ Product Serial Number: KKU276286 Product Code : 0587454 Module Code : 0204282 Basic Production Code: 0575069 Long Production SN : 0 PPM SW Version : V 09.10 25-08-09 RM-443 (c) Nokia D BT MCM Version : 410B-v170 MCU SW Version : V 09.10 25-08-09 RM-443 (c) Nokia HW Version : 2002 RFIC Version : 0831 DSP Version : ICPR81_09w10_pre LCD Version : SEIKO Content Pack Version : Content: d_matt_black T-MOBILE MK 25-08-09 RM-443 (c) Nokia AHNE Version : 30 RETU Version : 15 TAHVO Version : 22 Bluetooth ID : A8:7E:33:17:3D:48 CS Type : GSM900, GSM1800, GSM1900 ================================================ Simlock Information ================================================ CONFIG KEY : 8000000000000000 PROVIDER KEY : 2940100016517386 NETWORK NAME : T-Mobile ;Macedonia [GSM] LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST | |
06-04-2013, 21:04 | #12 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: colombia
Member: 576776 Status: Offline Thanks Meter: 133 | Quote:
can upload code for run V0.13 of oclhashcat-lite , and restore funtion thnaks i have a computer with 3 ati 5970 | |
