04-05-2014, 19:45 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Use ATFJ.exe v 1.0.6 Select Lumia_610.610C.afp Follow ATFJ instructions carefully And double check your JTAG wires |
04-05-2014, 20:00 | #3 (permalink) | |
No Life Poster Join Date: Aug 2011 Location: United Kingdom
Member: 1638915 Status: Offline Thanks Meter: 432 | Quote:
and I m unlock many Lumia With ATF but 1st time This happen N i m sure my connection 100% right Becose After connect i m test with multi meter | |
04-05-2014, 20:10 | #4 (permalink) | |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
Are you using ATFJ 1.0.6? Better post software screen shot, there is a button to make screen shot in software already. | |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
04-06-2014, 12:08 | #6 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Solution: 1. Delete C:\AdvanceBox Tubro Flasher\ATFJ.ini 2. Download and Install Full Setup v1.0.6 3. Open ATFJ.exe and Select: C:\AdvanceBox Turbo Flasher\Phones\UNLOCK\LUMIA_510_UNLOCK.afp 4. Make sure JTAG connection is fine and then click on Read Codes, then Connect USB cable to phone 5. Follow ATFJ.exe instructions carefully BR |
04-06-2014, 13:12 | #7 (permalink) |
Member: 1638915 Status: Offline Thanks Meter: 432 | Still Same Error full uninstall install agin Wen I m Selact 510 afp Not Found phone N I M selact 610_610C_510_505_ALL_LEVELS_UNLOCK_V2.afp Same Error i m Chak Test Point 4 Time Last edited by bux_harun; 04-06-2014 at 13:17. |
04-07-2014, 11:49 | #9 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @bux_harun You DO NOT have to use ALL_LEVEL_UNLOCK.afp. As I said, use only 510.afp file. Timeout during operation error because you did not follow the software instructions or JTAG connection is wrong. BR |
04-07-2014, 13:44 | #10 (permalink) |
Member: 1638915 Status: Offline Thanks Meter: 432 | bro ..::Angel::.. i m 100% sure my JTAG connection after conect phone i m test with multimeter N Now Not 1st time Unlock If u not believe on me i m put hire before unlock Images i m unlock more than 10+ hanset and wen i m use 510 afp n conect phone with atf after concet usb phone pick driver on pc QSUSB but ATF NOT Found Phone Last edited by bux_harun; 04-07-2014 at 13:50. |
04-09-2014, 11:23 | #13 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @bux_harun Can you power on this phone with battery? Looks like phone is Dead Boot. You need to repair boot first, if it can't power on with charged battery. BR |
