07-27-2015, 08:22 | #31 (permalink) | ||
Product Manager Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,978 | Nokia 520 rm-914 problem - Unable to find bootable option flashing log... Quote:
Scan remove write protection Write LUMIA_520_RM-914_BIG_BOOT.mmc After try again flash but still same Quote:
07-27-2015, 08:44 | #32 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: GSM WORLD
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | Quote:
EMMC Write Protection Problem Connect Direct EMMC And Remove Write Protection But Must Take Backup Before Doing Any Thing Your EMMC Still Write Protected | |
07-27-2015, 09:10 | #35 (permalink) | |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,978 | That "YES" Its before Perfrom/Remove Quote:
08-01-2015, 10:03 | #38 (permalink) | |
Junior Member Join Date: Mar 2010
Member: 1253983 Status: Offline Thanks Meter: 1 | Quote:
10-12-2015, 14:56 | #40 (permalink) |
No Life Poster Join Date: Nov 2003
Member: 44904 Status: Offline Thanks Meter: 45 | hello everyone !!!!! i solved 520 (rm-914) unable to find bootable option 2 pcs today i try another one now to confirm succes is simple Last edited by 936mw; 10-12-2015 at 15:02. |
10-12-2015, 15:53 | #41 (permalink) |
Member: 44904 Status: Offline Thanks Meter: 45 | succes solution Lunia 520 Rm-914 ** unable to find a bootable option ** no need remove shild EMMC or procesor.... no remove protection emmc...... need ATF JTAG select LUMIA_520_520T_525_526_FFU_FLASHER.afp conect usb to jtag and usb reset jtag custum R/W select RM914_3058.50000.1425.0003_RETAIL_eu_hungary_422_0 3_447211_prd_signed.ffu log: ATF JTAG v1.0.15.8544 (17/06/2015) Default language ID 0x0809, LR 14 JTAG Interface ATF Box Not Activated for JTAG. Checking ATF JTAG Activation from Server...OK JTAG Interface Connected, S/N 0xF Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 03/09/2014 14:26:00 ================================================== ======== Phone Type : Lumia 520, 520T, 525, 526 CPU Type : Qualcomm MSM8227 Storage Type: eMMC 8GB Procedure : WP8 FFU Flasher via JTAG More Info : <<<<<<<< ATF JTAG Lumia WP8 FFU Flashing Procedure >>>>>>>> - GSM-Forum ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x4F1F0F0F IR4 Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004D38473259430095EDC07DA0AB Flash Description: Samsung M8G2YC, 7.28 GiB, SN 95ED..., Oct 1997 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (5998 Op/Sec) FFU File Loaded: RM914_3058.50000.1425.0003_RETAIL_eu_hungary_422_0 3_447211_prd_signed.ffu FFU File CRC-32: Computing, Please wait...0x643720E0 Analyzing FFU, please wait...OK Restoring MBR Data...OK Restoring GPT Data from Backup...OK Writing "SBL1" area, flash #1, p#0, 0x0001000000, 0x0000180000...OK Writing "SBL2" area, flash #1, p#0, 0x0001200000, 0x0000180000...OK Writing "SBL3" area, flash #1, p#0, 0x0001400000, 0x0000200000...OK Writing "UEFI" area, flash #1, p#0, 0x0001600000, 0x0000200000...OK Writing "RPM" area, flash #1, p#0, 0x0001A00000, 0x0000080000...OK Writing "TZ" area, flash #1, p#0, 0x0001C00000, 0x0000080000...OK Writing "WINSECAPP" area, flash #1, p#0, 0x0001E00000, 0x0000080000...OK Writing "PLAT" area, flash #1, p#0, 0x0003400000, 0x0000264000...OK Writing "EFIESP" area, flash #1, p#0, 0x0004000000, 0x0000972C00...OK Writing "MMOS" area, flash #1, p#0, 0x0008C00000, 0x0004BC8000...OK Completed in 0h 5m 16s. Code Download Speed 310 KiB/sec. :::::::::::::::::::::::::::::::: assembly phone and flash normal Nokia Phone Info Mode Initiated... Please wait upto 15 Seconds for SW Reset IMEI: 3599650537jhgh Version: 1.1.1.3 Product Code: 059S1N6 Module Code: 0205435 Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00E90000 Block ID 0x05 : Nokia.MSM8227.P6036.1.2 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100130000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 02010F011C00 UEFI App: FLASH APP Flash App Protocol Version: 1.15 Flash App Implementation Version: 1.28 Query ROOT KEY HASH... ROOT_KEY_HASH: F771E62AF89994064F77CD3BC16829503BDF9A3D506D3FACEC AEF3F808C868FD Query PUBLIC ID... PUBLIC_ID: 00AF06ECD99D9E868ECF986FE93C366BE09C27D5 Query eMMC Info... EMMC Manufacture ID: SAMSUNG EMMC Product SN : 3E1ABCB3 EMMC_SIZE: 8 Gigabytes Query Battery Charge Status... BATTERY CHARGE_STATUS: 4% Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... Finished Sending all DATA BLOCKS! Exiting FLASH Mode via REBOOT... Exit FLASH Mode Successful! Flashing Done! Total Flashing Time : 00:04:02 |
12-03-2015, 07:49 | #45 (permalink) |
Freak Poster Join Date: Dec 2002 Location: ...
Member: 18642 Status: Offline Thanks Meter: 44 | Hi all, It only works with Samsung chips. With Hynix does not work. Log below. Phone Type : Lumia 520, 520T, 525, 526 CPU Type : Qualcomm MSM8227 Storage Type: eMMC 8GB Procedure : WP8 FFU Flasher via JTAG More Info : <<<<<<<< ATF JTAG Lumia WP8 FFU Flashing Procedure >>>>>>>> - GSM-Forum ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x4F1F0F0F IR4 Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...90014A48384732640401010A048A61C3 Flash Description: Hynix H8G2d, 7.23 GiB, SN 010A048A, Jun 1998 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (3257 Op/Sec) FFU File Loaded: RM914_3058.50000.1425.0008_RETAIL_eu_poland_302_08 _443021_prd_signed.ffu FFU File CRC-32: Computing, Please wait...0xCFFB5435 Analyzing FFU, please wait...OK Restoring MBR Data...OK Restoring GPT Data from Backup...Flash Write Error at 0x00000200, Loader Error, Code 0x75 Please send this log and "..\Logs\.log" file to support! |
The Following User Says Thank You to zaworek For This Useful Post: |
