10-29-2015, 11:48 | #1 (permalink) |
Freak Poster Join Date: Nov 2008 Location: türkey AKSARAY
Member: 897899 Status: Offline Thanks Meter: 36 | Lumİa 625 rm-941 boot repaİr ok Phone Type : Lumia 625 CPU Type : Qualcomm MSM8227 Storage Type: eMMC 8GB Procedure : WP8 FFU Flasher via JTAG More Info : <<<<<<<< ATF JTAG Lumia WP8 FFU Flashing Procedure >>>>>>>> - GSM-Forum ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x4F1F0F0F IR4 Loading AFP (Please Wait)...OK AFP revision 4, compiled 25.06.2014 23:03:00 ================================================== ======== Phone Type : Lumia 625 RM-941 CPU Type : Qualcomm MSM8930 Storage Type: eMMC 8GB Boot Package: 3056.40000.1402.1005 (BIG BOOT) ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x4F1F0F0F IR4 Restore Boot... Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core with 100ms Delay...OK Initializing Device...OK Detecting eMMC #1 ID...1501004D3847325943003C564B13806F Flash Description: Samsung M8G2YC, 7.28 GiB, SN 3C564B13, Aug 1997 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (3263 Op/Sec) Restoring MBR Data...OK Restoring GPT Data from AFP...OK Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...OK Restoring Partition #5...OK Restoring Partition #6...OK Restoring Partition #7...OK Restoring Partition #8...OK Restoring Partition #9...OK Restoring Partition #10...OK Completed in 0h 10m 10s. Code Download Speed 289 KiB/sec. Boot Restore Done! ================================================== =========== Assemble Phone and Start Normally If Phone cannot Start, perform USB Firmware Update Procedure ================================================== =========== ATF JTAG v1.0.15.8544 (17.06.2015) Default language ID 0x041F, LR 14 JTAG Interface Connected, S/N 0xA88F9400 Resetting and Exploring JTAG chain...No Devices found in Chain! |
10-29-2015, 11:50 | #2 (permalink) |
Member: 897899 Status: Offline Thanks Meter: 36 | lumia 625 rm-941 FLASH OK 13:24:58 : [DEAD BOOT REPAIR via USB is SUPPORTED] 13:24:58 : 13:24:58 : ================================================== ==== 13:24:58 : Windows Phone 8/8.1/10 Lumia Flasher 13:24:58 : ================================================== ==== 13:24:58 : 13:24:58 : If the Phone is ALIVE 13:24:58 : 1. Power On the Phone and Connect it to the USB Port 13:24:58 : 13:24:58 : If the Phone is DEAD 13:24:58 : 1. Connect Phone to the USB Port 13:24:58 : 2. Press and Hold the VOLUME DOWN and POWER Buttons 13:24:58 : 3. Wait until the Phone Vibrates Shortly... 13:24:58 : 4. Stop Pressing the Buttons... 13:24:58 : 13:24:58 : If the Phone is DEAD BOOT 13:24:58 : 1. Connect Phone to the USB Port 13:24:58 : 2. Install Correct Drivers: 13:24:58 : "Nokia Emergency Connectivity" Located at: 13:24:59 : 13:24:59 : C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\ 13:24:59 : ================================================== ==== 13:24:59 : 13:25:08 : Nokia Phone Info Mode Initiated... 13:25:08 : Please wait upto 15 Seconds for SW Reset 13:25:08 : IMEI: 356689XXXXXXXXXXXXX 13:25:08 : Version: 1.1.1.3 13:25:08 : Product Code: 059T7L5 13:25:08 : Module Code: 0205628 13:25:09 : 13:25:09 : Continuing Previous Boot... 13:25:09 : Please wait upto 30 Seconds for Boot Re-entry 13:25:43 : 13:25:43 : Boot Flash Mode Successful... 13:25:44 : Buffers Flushed OK... 13:25:44 : 13:25:44 : Phone Info Query Start... 13:25:44 : Blocks Returned: 0x07 Blocks 13:25:44 : Block ID 0x01 :00241000 13:25:44 : Block ID 0x02 :00240000 13:25:44 : Block ID 0x03 :00E90000 13:25:44 : Block ID 0x05 :Nokia.MSM8930.P6083.1.2 13:25:44 : Block ID 0x0D :0001 13:25:44 : Block ID 0x0F :0301010100000101FF 13:25:44 : Block ID 0x10 :0100130000 13:25:44 : Checking SD Card Size... 13:25:44 : Card Size: 0x00000000 13:25:44 : Checking Platform Security Status... 13:25:44 : Platform Secure Boot Status: Active 13:25:44 : Secure FFU EFUSE Status: Active 13:25:44 : Debug Status: Active 13:25:44 : RDC Status: Not Active 13:25:44 : Authentication Status: Not Active 13:25:44 : UEFI Secure Boot Status: Active 13:25:44 : Checking Secure FFU Mode... 13:25:44 : Secure FFU Mode : 13:25:44 : Query Flash App Information... 13:25:44 : Flash App Information: 02010F011C00 13:25:44 : UEFI App: FLASH APP 13:25:44 : Flash App Protocol Version: 1.15 13:25:44 : Flash App Implementation Version: 1.28 13:25:44 : Query ROOT KEY HASH... 13:25:44 : ROOT_KEY_HASH: 106D7E7DDC685B6E693326851A5DDACB7326B0297995A5BE00 3F724DEAE04EF2 13:25:44 : Query PUBLIC ID... 13:25:44 : PUBLIC_ID: 7ACF7BACD17E038347ECEB8968BDCE551EFACD77 13:25:44 : Query eMMC Info... 13:25:44 : EMMC Manufacture ID: SAMSUNG 13:25:44 : EMMC Product SN : 3C564B13 13:25:44 : EMMC_SIZE: 8 Gigabytes 13:25:44 : Query Battery Charge Status... 13:25:44 : BATTERY CHARGE_STATUS: 5% 13:25:44 : 13:25:44 : Sending Image Signatures... 13:25:45 : Image Signatures Accepted! 13:25:45 : Erasing Data Partition... 13:25:45 : Data Partition Erased Successfully 13:25:45 : Preparing Buffers for DATA LOOP... 13:25:45 : Allocating System RAM OK! 13:25:45 : Start Sending DATA BLOCKS... 13:28:44 : Finished Sending all DATA BLOCKS! 13:28:44 : Exiting FLASH Mode via REBOOT... 13:28:44 : Exit FLASH Mode Successful! 13:28:44 : 13:28:44 : Flashing Done! 13:28:44 : Total Flashing Time : 00:03:00 |
