02-08-2014, 08:08 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Afrique du sud Age: 42
Member: 430612 Status: Offline Thanks Meter: 301 | Lumia 1020 flashing fail Loading Flash Files Please Wait... ================================================== ==== Windows Phone 8 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ================================================== ==== Version: 1.1.1.3 Product Code: 059V260 Module Code: 0205303 Boot Flash Mode Successful... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00000000 Block ID 0x05 : Nokia.MSM8960.P5217.3.2.1 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100030000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : SYNC + ASYNC Query Flash App Information... Flash App Information: 02010E011900 UEFI App: FLASH APP Flash App Protocol Version: 1.14 Flash App Implementation Version: 1.25 Query ROOT KEY HASH... ROOT_KEY_HASH: 0CBD2EED6F62230571CBAB55B7DBC15F8A7DC7BB3F37C1E7E4 E5ADC77152FBC2 Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Fixing Partitions... Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... ERROR: DATA BLOCK REJECTED at 0x00300000 Check your Flash File and Phone Connection ERROR: Flashing Failed! plz help |
02-08-2014, 09:29 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | There has been a communication error during flashing that could havr been caused by one of the following: 1. corrupted flash file - click CHECK button 2. Low battery - 3. Usb cable got disconnected Reconnect everything and make sure your flash file is 101% ok Flash again |
The Following User Says Thank You to Advance-Box For This Useful Post: |
02-08-2014, 11:34 | #3 (permalink) | |
Member: 430612 Status: Offline Thanks Meter: 301 | Quote:
02-08-2014, 12:29 | #4 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @layunda Battery is dead, and you should have checked battery before you flashed it. Nokia Lumias are very hard to charge when they are dead. But try to charge it for 30 minutes or so. If it gets hot, then it means it is charging. |
02-08-2014, 12:37 | #5 (permalink) | |
ok no boot repair on this phone? can you plz help me with flash file? | |
