02-15-2016, 08:10 | #1 (permalink) |
No Life Poster Join Date: Dec 2012 Location: india mumbai
Member: 1847344 Status: Offline Thanks Meter: 300 | lumia 1090 flash succes Loading Flash Files Please Wait... [DEAD BOOT REPAIR via USB is SUPPORTED] ================================================== ==== Windows Phone 8/8.1/10 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" Located at: C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\ ================================================== ==== Nokia Phone Info Mode Initiated... Please wait upto 15 Seconds for SW Reset 1. Press and Hold the VOLUME DOWN and POWER 2. Wait until the Phone Reboots... 3. Wait until you see BIG "NOKIA" Logo 4. Stop Pressing the Buttons... Version: 2.5.2.11 Product Code: 059W6L6 Module Code: 0206286 Basic Tranceiver Code: 059W2B7 Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x09 Blocks Block ID 0x01 : 00241000 Block ID 0x1F : 01 Block ID 0x02 : 00240000 Block ID 0x03 : 00E90000 Block ID 0x05 : Nokia.MSM8212.P6214.1.1 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 01000F0000 Block ID 0x20 : 010000000100000004 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 020222023B00 UEFI App: FLASH APP Flash App Protocol Version: 2.34 Flash App Implementation Version: 2.59 Query ROOT KEY HASH... ROOT_KEY_HASH: BC2353ACA62C327ECCD582A281CA4A5672F35001D87176CCBF 3C87DBE215CA3B Query PUBLIC ID... PUBLIC_ID: 553475C2DE36A51AC3F90F328B2534A344F6A5C2 Query eMMC Info... EMMC Manufacture ID: SAMSUNG EMMC Product SN : 7D4ECAB5 EMMC_SIZE: 8 Gigabytes Query Battery Charge Status... BATTERY CHARGE_STATUS: 46% Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... Finished Sending all DATA BLOCKS! Exiting FLASH Mode via REBOOT... Exit FLASH Mode Successful! Flashing Done! Total Flashing Time : 00:07:35 here are driver solution https://www.youtube.com/watch?v=qikMkU9xEao |
