10-22-2015, 15:34 | #1 (permalink) |
No Life Poster Join Date: Oct 2010 Location: INDIA - GOING MY WAY ......... Age: 31
Member: 1417101 Status: Offline Sonork: 100.1619006 Thanks Meter: 157 | Lumia 1320 rm-994 error flashing Loading Flash Files Please Wait... [DEAD BOOT REPAIR via USB is SUPPORTED] ================================================== ==== Windows Phone 8/8.1/10 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" Located at: C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\ ================================================== ==== Nokia Phone Info Mode Initiated... Please wait upto 15 Seconds for SW Reset 1. Press and Hold the VOLUME DOWN and POWER 2. Wait until the Phone Reboots... 3. Wait until you see BIG "NOKIA" Logo 4. Stop Pressing the Buttons... IMEI: 359179050340917 Version: 1.1.1.3 Product Code: 059V6P2 Module Code: 0205881 Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00E90000 Block ID 0x05 : Nokia.MSM8930.P6145.2.0 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100130000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 02010F011C00 UEFI App: FLASH APP Flash App Protocol Version: 1.15 Flash App Implementation Version: 1.28 Query ROOT KEY HASH... ROOT_KEY_HASH: 64356634FCA08BC9E0D02C14BDB230B0076D31099C9779483D 27F9938EDB99C9 Query PUBLIC ID... PUBLIC_ID: 93151A1A96364E4D6920F407470CE9922D61E254 Query eMMC Info... EMMC Manufacture ID: SAMSUNG EMMC Product SN : D0BFBC5A EMMC_SIZE: 8 Gigabytes Query Battery Charge Status... CHARGING_STATUS: Cannot Read in Flash Mode Sending Image Signatures... ERROR: Flash Signature Block REJECTED! (0x11068000000E00000000) This Flash File is NOT COMPATIBLE with this Phone. ERROR: Flashing Failed! PROBLEM UNABLE TO FIND A BOOTABLE OPTION BUT I TRIED 3 DIFFRENT FILES THAT FILES ALSO SHOWING THE SAME ISSUE , ANY SOLUTION FOR THIS ? , I GOT MANY LUMIA 520 THE SAME PROBLEM ALL DONE WITH NORMAL FLASHING VIA ATF , PLS GIVE ME A GOOD SOLUTION MY ATF JTAG IS NOT ACTIVATED |
10-29-2015, 20:07 | #3 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Jamaica
Member: 244159 Status: Offline Thanks Meter: 16 | 1. Disconnect USB Cable 2. Disconnect Battery 3. Connect Battery 4. Try Again... ERROR: Flashing Failed! Windows Phone 8/8.1/10 Flashing Started Loading Flash Files Please Wait... [DEAD BOOT REPAIR via USB is SUPPORTED] ================================================== ==== Windows Phone 8/8.1/10 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" Located at: C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\ ================================================== ==== Process Cancelled... Recovery Handle Found! - (WinUSB) Sending Factory Loader... Loader Upload Done! Executing Loader... Start Loader Done! Waiting for USB Cycle... USB Cycle OK! Device Factory Mode OK! USB Reconfiguration Done... eMMC Detected OK... Extracting Partitions from FFU... Looking for SBL1... SBL1 OK Looking for SBL2... SBL2 OK Looking for SBL3... SBL3 OK Looking for UEFI... UEFI OK Looking for RPM... RPM OK Looking for TZ... TZ OK Looking for WINSECAPP... WINSECAPP OK Extracting Partitions Done! Start Writing eMMC Blocks at : 0x00000000 Start Writing eMMC Blocks at : 0x01000000 ERROR: eMMC WRITE Failed at 0x01000000 Skipping This Partition... Start Writing eMMC Blocks at : 0x01200000 ERROR: eMMC WRITE Failed at 0x01200000 7E0D07000000577269746520756E7375636365737366756CF0 5B7E ERROR: Flashing Failed! |
12-01-2015, 21:53 | #4 (permalink) |
No Life Poster Join Date: Sep 2008 Location: with mobile phone Age: 35
Member: 866865 Status: Offline Sonork: 1645198 Thanks Meter: 182 | We can never solve this error by flashing It is emmc problem Remove write protection via atf plus You need to connect via emmc test points and remove the write protection |
12-01-2015, 21:54 | #5 (permalink) |
The Following User Says Thank You to Pratheesh T K For This Useful Post: |
09-27-2016, 06:47 | #7 (permalink) |
Junior Member Join Date: Sep 2016
Member: 2629692 Status: Offline Thanks Meter: 0 | Hello all. My phone is Nokia 1320 Lumia. I have tried to flash it which I have done it before successfully but the flashing was terminated with fail message. Can anybody help me? |
