Hi,
Trying to flash phone but error occurs while battery is almost 88% charge, any help will be highly appreciated, following are logs,
18:44:15 : Make sure you have installed the
18:44:15 : COMPLETE Flash Package for this Phone...
18:44:15 :
18:44:15 : Goto "Settings" --> "Nokia Settings" and verify that
18:44:15 : the Folder where you installed your Flash Files are
18:44:15 : in the "PRODUCT PATH TO SCAN" List...
18:44:20 :
18:44:20 : ================================================== ====
18:44:20 : Selected VPL File:
18:44:20 : RM1069_059W978_02074.00000.15234.28005_031.vpl
18:44:20 : Variant Details : RM-1069 VAR IMEA PK CV
18:44:20 : Software Version : 02074.00000.15234.28005
18:44:20 : Product Type : RM-1069
18:44:20 : Product Code : 059W978
18:44:20 : Variant Version : 031
18:44:20 :
18:44:24 : Windows Phone 8/8.1/10 Flashing Started
18:44:24 : Loading Flash Files Please Wait...
18:44:24 :
18:44:24 : [DEAD BOOT REPAIR via USB is SUPPORTED]
18:44:25 :
18:44:25 : ================================================== ====
18:44:25 : Windows Phone 8/8.1/10 Lumia Flasher
18:44:25 :
18:44:25 : If the Phone is ALIVE
18:44:25 : 1. Power On the Phone and Connect it to the USB Port
18:44:25 :
18:44:25 : If the Phone is DEAD
18:44:25 : 1. Connect Phone to the USB Port
18:44:25 : 2. Press and Hold the VOLUME DOWN and POWER Buttons
18:44:25 : 3. Wait until the Phone Vibrates Shortly...
18:44:25 : 4. Stop Pressing the Buttons...
18:44:25 :
18:44:25 : If the Phone is DEAD BOOT
18:44:25 : 2. Install Correct Drivers:
18:44:25 : "Nokia Emergency Connectivity" Located at:
18:44:25 :
18:44:25 : C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\
18:44:25 :
18:44:30 : Nokia Phone Info Mode Initiated...
18:44:30 : Please wait upto 15 Seconds for SW Reset
18:44:43 :
18:44:43 : 1. Press and Hold the VOLUME DOWN and POWER
18:44:43 : 2. Wait until the Phone Reboots...
18:44:43 : 3. Wait until you see BIG "NOKIA" Logo
18:44:43 : 4. Stop Pressing the Buttons...
18:44:44 : Version: 2.5.2.11
18:44:44 : Product Code: 059W978
18:44:44 : Module Code: 0206250
18:44:44 : Basic Tranceiver Code: 059W1M8
18:44:45 :
18:44:45 : Continuing Previous Boot...
18:44:45 : Please wait upto 30 Seconds for Boot Re-entry
18:45:13 :
18:45:13 : Boot Flash Mode Successful...
18:45:13 : Buffers Flushed OK...
18:45:13 :
18:45:13 : Phone Info Query Start...
18:45:14 : Blocks Returned: 0x09 Blocks
18:45:14 : Block ID 0x01 :00241000
18:45:14 : Block ID 0x1F :01
18:45:14 : Block ID 0x02 :00240000
18:45:14 : Block ID 0x03 :00E90000
18:45:14 : Block ID 0x05 :Nokia.MSM8210.P6200.1.1
18:45:14 : Block ID 0x0D :0001
18:45:14 : Block ID 0x0F :0301010100000101FF
18:45:14 : Block ID 0x10 :01000F0000
18:45:14 : Block ID 0x20 :010000000100000004
18:45:14 : Checking SD Card Size...
18:45:14 : Card Size: 0x00000000
18:45:14 : Checking Platform Security Status...
18:45:14 : Platform Secure Boot Status: Active
18:45:14 : Secure FFU EFUSE Status: Active
18:45:14 : Debug Status: Active
18:45:14 : RDC Status: Not Active
18:45:14 : Authentication Status: Not Active
18:45:14 : UEFI Secure Boot Status: Active
18:45:14 : Checking Secure FFU Mode...
18:45:14 : Secure FFU Mode :
18:45:14 : Query Flash App Information...
18:45:14 : Flash App Information: 020222023B00
18:45:14 : UEFI App: FLASH APP
18:45:14 : Flash App Protocol Version: 2.34
18:45:14 : Flash App Implementation Version: 2.59
18:45:14 : Query ROOT KEY HASH...
18:45:14 : ROOT_KEY_HASH: 80F2F707F2EF1F5650E81C07A552E2B911896BB046EB7D33D6 99F736B29FF74B
18:45:14 : Query PUBLIC ID...
18:45:14 : PUBLIC_ID: 08C26668603FD9891812D5DC4FAC299A91C44210
18:45:14 : Query eMMC Info...
18:45:14 : EMMC Manufacture ID: SAMSUNG
18:45:14 : EMMC Product SN : A723C64A
18:45:14 : EMMC_SIZE: 8 Gigabytes
18:45:14 : Query Battery Charge Status...
18:45:14 : BATTERY CHARGE_STATUS: 88%
18:45:14 :
18:45:14 : Sending Image Signatures...
18:45:14 : Image Signatures Accepted!
18:45:14 : Erasing Data Partition...
18:45:14 : Data Partition Erased Successfully
18:45:14 : Fixing Partitions...
18:45:15 : Preparing Buffers for DATA LOOP...
18:45:15 : Allocating System RAM OK!
18:45:15 : Start Sending DATA BLOCKS...
18:45:33 : ERROR: DATA BLOCK REJECTED at 0x04B00000
18:45:33 : Check your Flash File and Phone Connection
18:45:33 : ERROR: Flashing Failed!
Thanks
Regards
