02-01-2014, 18:46 | #2 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V 1.9-2.0V CID : 1501004D344731464203891A7CA9 CSD : D02701320F5903FFF6DBFFE78A404057 ERROR: EMMC_SEND_EXT_CSD (CMD8) Check GREEN Test Point Connection BOOT Images Written Successfully! Total Elapsed Time 00:00:04 |
02-01-2014, 20:48 | #3 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi Umer, you are using wrong method to unlock lumia 610. You got to use JTAG software for unlock and NOT ATF main software... Those eMMC Pinouts are only for Boot Repair. For unlock lumia 505, 510, 610 and 900 - use only ATF JTAG software and it's Pinouts. Anyway, at first post the log of the operation you have made till now, than I will tell you the repair procedure. BR |
02-02-2014, 08:40 | #4 (permalink) | |
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | Quote:
