12-02-2013, 18:02 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: South africa Age: 35
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | lumia 510 flashing problem Data Rejected at SEQ 0x1 ERROR: Data Rejected at SEQ 0x2 Sending AMSS Certificate HASH: B131DA19CE3B6B5F965AE2F2947199519A5F3279 Certificate Size: 449 Bytes ERROR: Data Rejected at SEQ 0x3 Status : WRITE AMSS CERTIFICATE FAILED now fone show just vibrate and nokia blue screen any solution |
12-03-2013, 12:29 | #4 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @saleem5001 Your screenshot show 100% that it is LOW BATTERY. I am sure about this. Now if you are getting other error now, then you need to post another screenshot. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
12-03-2013, 17:42 | #5 (permalink) | |
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | Quote:
if me use other tool than other tool stuck when this fone connect so now me send to nokia care center | |
07-16-2014, 14:25 | #7 (permalink) |
No Life Poster Join Date: Apr 2009 Location: rainak bazar jalandhar
Member: 1002949 Status: Offline Sonork: 100.1582346 Thanks Meter: 273 | i have same issue If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME UP button 2. Connect it to the USB Port while still Pressing the VOLUME UP button 3. Continue to Press the VOLUME UP button for 8 more seconds ================================================== ==== ERROR: Data Rejected at SEQ 0x1 ERROR: Data Rejected at SEQ 0x2 Sending AMSS Certificate HASH: B131DA19CE3B6B5F965AE2F2947199519A5F3279 Certificate Size: 449 Bytes ERROR: Data Rejected at SEQ 0x3 Status : WRITE AMSS CERTIFICATE FAILED |
07-16-2014, 14:30 | #8 (permalink) |
No Life Poster Join Date: Apr 2010 Location: chirala
Member: 1293395 Status: Offline Sonork: 100.1657302 Thanks Meter: 87 | some times this type of problem cmes from battery problem do flash it with same product code it will work i face this problem so flash it with same product code.... |
