05-22-2014, 12:52 | #1 (permalink) |
No Life Poster Join Date: Oct 2010 Location: colombo
Member: 1418524 Status: Offline Thanks Meter: 186 | lumia 510 unlock problem AFP revision 4, compiled 11/26/2013 10:47:00 AM ================================================== ======== Phone Type : Lumia 510 RM-889 - Supported : Lumia 510 RM-898 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click READ CODES button to Start Reading Unlock Codes ---------------------------------------------------------- Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...Timeout During Operation!Timeout During Operation! |
05-23-2014, 11:00 | #4 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @gsaara Check your JTAG connection. Phone was just not detected. Also, make sure you are using latest EXE v1.0.7 and file: LUMIA_510_UNLOCK.afp BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
05-23-2014, 18:09 | #5 (permalink) |
Cheater -Don't Deal with him- Join Date: Mar 2006 Location: ACCRA GHANA Age: 39
Member: 244250 Status: Offline Sonork: 100.160773 Thanks Meter: 196 | Phone Type : Lumia 900 RM-808, RM-823 Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Automatic Counter Reset (If Needed) ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY Flex Cable 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect USB Cable to Phone 5. Use RESET JTAG button to check the JTAG Connection 6. Click RESTORE BOOT button to Start Reading Unlock Codes ---------------------------------------------------------- need help Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting ONFI #1 ID...ONFI Signature Not Found! |
05-24-2014, 13:23 | #6 (permalink) |
Member: 1418524 Status: Offline Thanks Meter: 186 | Default language ID 0x0409 JTAG Interface Connected, S/N 0000000000000 Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 11/26/2013 10:47:00 AM ================================================== ======== Phone Type : Lumia 510 RM-889 - Supported : Lumia 510 RM-898 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click READ CODES button to Start Reading Unlock Codes ---------------------------------------------------------- Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Retrieving Unlock Codes...OK =================================== Service Provider Unlock Codes Found =================================== Level 1 PIN: 49612106 ACTIVE Level 1 PUK: 03552427 ACTIVE Level 2 PIN: 05586904 Level 2 PUK: 16223889 Level 3 PIN: 44397728 ACTIVE Level 3 PUK: 20874130 ACTIVE Level 4 PIN: 28997991 Level 4 PUK: 73191240 Level 5 PIN: 95231922 Level 5 PUK: 14253488 =================================== Reading Unlock Codes Done! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ================================================== ========================== unlock Done |
