10-05-2015, 10:15 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 46
Member: 138982 Status: Offline Thanks Meter: 138 | Lumia 520 Now there is only boot screen logo ( big nokia) only. When itry to flash is gave this error ERROR: Flash Signature Block REJECTED! (0x11068000000E00000000) This Flash File is NOT COMPATIBLE with this Phone. ERROR: Flashing Failed Then i use emmc tool of atf and there is log here Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501004D384732594300720664B06049 CSD : D02701320F5903FFF6DBFFEF96404063 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 512 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : M8G2YC Product Rev : 0.0 Product SN : 720664B0 Manufactured : June 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501004D384732594300720664B06049.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Write protection off although i follow whole procedure but cannt flash phone Plz help Thanks |
10-11-2015, 11:58 | #8 (permalink) |
Member: 138982 Status: Offline Thanks Meter: 138 | finally i flashed phone by following method 1. First apply tp for emmc scan 2. scan emmc 3. read user are of 512mb 4. after write protection removed i write that readed 512 mb file. But everytime i fail for flashing so i read 512 mb of user data from working phone and write that file instaed of original readed file. After this i flashed phone sucessully but caant exit "FLIGHT MODE" I use Infinity Best also for flight mode with diffrent version but fail Solution needed |
