06-06-2015, 18:19 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: GSM WORLD
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | Lumia 520 After EMMC Write Protection Remove Dead Specially From Advance-Box For Lumia 520 Condition When I Got ERROR : Unable to find a bootable option. press any key to shutdown First EMMC Info Code: Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501004D3847325943002310BCF6A0A5 CSD : D02701320F5903FFF6DBFFEF96406007 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 512 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : M8G2YC Product Rev : 0.0 Product SN : 2310BCF6 Manufactured : October 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: YES TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501004D3847325943002310BCF6A0A5.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ ERROR: Invalid Block Input Taken 512 MB Backup Dump Code: Custom Block Read OK File Saved: C:\AdvanceBox Turbo Flasher\eMMC\Recovered\Lumia_520_512MB_Dump_0x00000000_0x000FFFFF.bin Code: Task Selected: Samsung Remove Write Protection ====================================================== DO NOT PERFORM THIS ON A NON SAMSUNG BRAND EMMC Make Sure you BACKUP eMMC DUMP Just In Case... ====================================================== Permanent Write Protection Removed! Perform USB Firmware Update if Needed... After This Tried Samsung eMMC Firmware Update Code: Task Selected: Samsung eMMC Firmware Update ====================================================== This will ERASE USER AREA, BOOT1, BOOT2, and RPMB This will RESET EXT_CSD Programming Such as BOOT Options, Bus Characteristics and Partition Sizes.. ====================================================== ====================================================== Loading ATF eMMC Firmware File... (Please Wait) ====================================================== File Author: ATF Team @ X-Shadow Date Created: 19/03/2015 (dd/mm/yyyy) Description: Samsung eMMC Firmware eMMC Part Number: KLM8G2YE4C-C001 eMMC Product Name: M8G2YC eMMC Product Rev: 0.0 Preparing eMMC for Firmware Update... Sending eMMC Firmware Blocks... All Blocks Sent! NAND Write Delay: 1 Second (Please Wait) Verifying eMMC Firmware... eMMC Firmware Verify OK! Applying eMMC Firmware Update... Waiting for Device Re-Initialization... Firmware Write Protect Delay: 1 Second (Please Wait) Checking eMMC Firmware Update Status... eMMC Firmware Update Successful! After This Written BIG_BOOT.mmc Code: ====================================================== Loading ATF MMC File... (Please Wait) ====================================================== MMC File Version: v11.30 MMC File Author: 963F2A3CB175EDB4B4358C42 Date Created: 05/07/2014 (dd/mm/yyyy) Description: Lumia 520 RM-914 BIG BOOT V2 [3056.40000.1408.0007] Current Partition: Partition 1 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 2 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 3 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 4 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 5 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 6 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 7 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 8 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 9 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 10 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 11 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 12 Start Writing Blocks... Writing Blocks Done! After This Written 512 MB Dump Back To Fone Code: eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 512 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : M8G2YC Product Rev : 0.0 Product SN : 2310BCF6 Manufactured : October 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501004D3847325943002310BCF6A0A5.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Start Writing 0x00100000 Blocks at 0x00000000 Partition Selected: USER AREA Total Elapsed Time 00:09:43 Write Success! I Need Help Plz Thanks Anticipation |
06-06-2015, 22:05 | #4 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @shoaibrao, but are sure that this Lumia haven't other type of problem?...all procedures are with success...for me must nee of ceck any HW side in the phone...EMMC is OK... BR allumts |
06-07-2015, 09:05 | #5 (permalink) | |
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | Quote:
Condition When I Got ERROR : Unable to find a bootable option. press any key to shutdown | |
06-07-2015, 09:32 | #7 (permalink) | |
Code: ====================================================== Loading ATF MMC File... (Please Wait) ====================================================== MMC File Version: v11.30 MMC File Author: 963F2A3CB175EDB4B4358C42 Date Created: 05/07/2014 (dd/mm/yyyy) Description: Lumia 520 RM-914 BIG BOOT V2 [3056.40000.1408.0007] Current Partition: Partition 1 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 2 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 3 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 4 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 5 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 6 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 7 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 8 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 9 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 10 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 11 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 12 Start Writing Blocks... Writing Blocks Done! | |
06-07-2015, 09:35 | #8 (permalink) |
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | ATF Flashing Error Code: WINSECAPP OK Extracting Partitions Done! Start Writing eMMC Blocks at : 0x00000000 Start Writing eMMC Blocks at : 0x01000000 ERROR: eMMC WRITE Failed at 0x01000000 Skipping This Partition... Start Writing eMMC Blocks at : 0x01200000 ERROR: eMMC WRITE Failed at 0x01200000 7E0D07000000577269746520756E7375636365737366756CF05B7E ERROR: Flashing Failed! |
06-07-2015, 11:19 | #9 (permalink) |
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | Ah I Think ATF Have Some Bugs With Apology To ATF Team I Want To Mention Here That I Repaired This Fone With Other Tool But ATF Is Still My Favorite Tool Just Request To Advance-Box Sir Plz Try To Work On Bugs Removing Plz |
06-07-2015, 12:10 | #10 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
I know you are NOT new to field... But why did you use "Firmware Update Only" ??? You need to repair emmc with "Firmware Update + Format"... keep in mind, your emmc was WP ON because it had bugs... Good thing you backup 512mb, this was smart move on your side. Because emmc has bugs, it can only be "refreshed" via Firmware Update + Format... On next version, I will remove this "Firmware Update Only" ... Seems it causes confusion to end users. | |
06-07-2015, 12:24 | #11 (permalink) | |
http://forum.gsmhosting.com/vbb/11020784-post2.html And Sir My Fone Was Dead After Only " Samsung Remove Write Protection " And "Samsung eMMC Firmware Update " I Applied On Dead Fone ( I Thought IT May Help To Me) | |
06-07-2015, 12:44 | #12 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @Yes shoaibrao, i'm lol for not to think in this FORMAT option....and i've seen very many peoples with Samsung and Lumia in the same condition after "Update Fw only"... later when have applied "Format+Update FW"...problem in writing is been solved.... And think that have used the same "Format+Update fw" just yesterday in one N7100 with TP inside the emmc...lol for not have tinked in this... BR allumts |
06-07-2015, 13:07 | #13 (permalink) | |
Not all eMMC WP Problem is the same... Some can repair via "Remove WP" only and some will die with "Remove WP" only. It does not matter which Box/Tool you use... Your best bet is always to backup 512MB while you can. Then always perform Firmware Update + Format | |
06-07-2015, 13:15 | #14 (permalink) |
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | @Advance-Box Sir Fone Can Be Relocked To Network After " Samsung Remove Write Protection " ? Now Its Asking For Codes And Customer Claiming It Was Unlocked Before This Problem Its Strange For Me Product Type: RM-914 Product Code: 059T138 I Have Its 512 MB Dump Before Any Operation |
