07-13-2015, 10:19 | #1 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2227394 Status: Offline Thanks Meter: 1 | Lumia 520 Cannot b Flashed Always getting this .. Changed Flash files 3 times Always Same Code: 09:41:59 : 1. Press and Hold the VOLUME DOWN and POWER 09:41:59 : 2. Wait until the Phone Reboots... 09:41:59 : 3. Wait until you see BIG "NOKIA" Logo 09:41:59 : 4. Stop Pressing the Buttons... 09:42:07 : 09:42:07 : Continuing Previous Boot... 09:42:07 : Please wait upto 30 Seconds for Boot Re-entry 09:42:38 : 09:42:38 : Boot Flash Mode Successful... 09:42:38 : Buffers Flushed OK... 09:42:38 : 09:42:38 : Phone Info Query Start... 09:42:38 : Blocks Returned: 0x07 Blocks 09:42:38 : Block ID 0x01 :00241000 09:42:38 : Block ID 0x02 :00240000 09:42:39 : Block ID 0x03 :00E90000 09:42:39 : Block ID 0x05 :Nokia.MSM8227.P6036.1.2 09:42:39 : Block ID 0x0D :0001 09:42:39 : Block ID 0x0F :0301010100000101FF 09:42:39 : Block ID 0x10 :0100030000 09:42:39 : Checking SD Card Size... 09:42:39 : Card Size: 0x00000000 09:42:39 : Checking Platform Security Status... 09:42:39 : Platform Secure Boot Status: Active 09:42:39 : Secure FFU EFUSE Status: Active 09:42:39 : Debug Status: Active 09:42:39 : RDC Status: Not Active 09:42:40 : Authentication Status: Not Active 09:42:40 : UEFI Secure Boot Status: Active 09:42:40 : Checking Secure FFU Mode... 09:42:40 : Secure FFU Mode : SYNC + ASYNC 09:42:40 : Query Flash App Information... 09:42:40 : Flash App Information: 02010E011900 09:42:40 : UEFI App: FLASH APP 09:42:40 : Flash App Protocol Version: 1.14 09:42:40 : Flash App Implementation Version: 1.25 09:42:40 : Query ROOT KEY HASH... 09:42:40 : ROOT_KEY_HASH: F771E62AF89994064F77CD3BC16829503BDF9A3D506D3FACECAEF3F808C868FD 09:42:40 : Query PUBLIC ID... 09:42:40 : PUBLIC_ID: BDFEC4234C83E47A67016F1E91814A33CFD858D0 09:42:40 : Query eMMC Info... 09:42:40 : EMMC Manufacture ID: SAMSUNG 09:42:41 : EMMC Product SN : 5235BCDD 09:42:41 : EMMC_SIZE: 8 Gigabytes 09:42:41 : Query Battery Charge Status... 09:42:41 : BATTERY CHARGE_STATUS: 86% 09:42:41 : 09:42:41 : Sending Image Signatures... 09:42:41 : Image Signatures Accepted! 09:42:41 : Erasing Data Partition... 09:42:41 : Data Partition Erased Successfully 09:42:41 : Fixing Partitions... 09:42:41 : Preparing Buffers for DATA LOOP... 09:42:42 : Allocating System RAM OK! 09:42:42 : Start Sending DATA BLOCKS... 09:42:42 : ERROR: DATA BLOCK REJECTED at 0x00320000 09:42:42 : Check your Flash File and Phone Connection 09:42:42 : ERROR: Flashing Failed! |
07-13-2015, 16:05 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @christo369 Your eMMC is BAD... You can only repair this phone via eMMC Connection. Pinouts can be found here: C:\AdvanceBox Turbo Flasher\Nokia\Lumia\TP_PIX\ Just connect 4 wires and plug the USB cable... Follow STEPS in exact Order: 1. Backup "USER AREA" Partition 1 GB 2. Keep the BACKUP FILE in a safe place. 3. Perform "Samsung eMMC Firmware Update + Format" 4. Write BACK "EXT_CSD" file which is saved by ATF Software each time you "SCAN EMMC" 5. Make sure the BOOT is set to "USER AREA" (this is done by the EXT_CSD File) 6. Write back 1 GB which you made backup from step 1. 7. Remove wires, assemble phone and flash it via USB. Problem solved. |
