08-20-2014, 07:35 | #4 (permalink) |
No Life Poster Join Date: Oct 2010 Location: colombo
Member: 1418524 Status: Offline Thanks Meter: 186 | yes red screen flash only 7% 20% & restart phone flash mode now i try boot repair ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 90014A4838473264040100BE3693 CSD : D02701320F5903FFFFFFFFEF8A4040D3 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 7759462400 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 2048 KB eMMC Device Information Manufacturer ID: HYNIX Device Type : Embedded BGA Application ID : 4A Product Name : H8G2d Product Rev : 0.1 Product SN : 00BE3693 Manufactured : November 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 90014A4838473264040100BE3693_5EAAC9CA.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Writing MBR + GPT... Write Success! Writing SBL1... Block Write CRC Error ERROR: Block Write Failed at 0x0000824D Check your Test Point Soldering! ERROR: WRITE FAILED! Total Elapsed Time 00:00:20 |
08-21-2014, 09:42 | #5 (permalink) |
Member: 1418524 Status: Offline Thanks Meter: 186 | Quote: wait iam hear need help............................. |
