05-02-2015, 05:29 | #1 (permalink) | ||
No Life Poster Join Date: Jan 2005 Location: the earth Age: 41
Member: 103024 Status: Offline Thanks Meter: 616 | Lumia 520 problem emmc wp removed I HAVE A NOKIA 520 WITH THIS PROBLEM " Error : Unable to find a boot loader option. Press any key to shutdown " AFTER REMOVE WRITE PROTECTION ON EMMC SAMSUNG , THEN PHONE COMES PARTIAL DEAD TRY TO RECOVER WITH WIN USB EMERGENCY OPTION BUT FAIL ANY SUGESTION ? HERE IS THE LOG EMMC WRITE PROTECTION REMOVAL Quote:
THEN TRY TO FLASH USING EMERGENCY MODE Quote:
PLEASE LET ME KNOW IF I DO SOMETHING WRONG OR GIVE ME AN ADVICE THANKS IN ADVANCED BR ROGER | ||
05-02-2015, 06:44 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @roger Repair via USB cannot repair phones from WP problem. You need to write 520 boot via emmc or via jtag connection. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
05-02-2015, 06:48 | #3 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Here you can download boot repair files for emmc or for jtag. http://forum.gsmhosting.com/vbb/f609...735-a-1830880/ After you repair phone, tell phone owner NEVER to put 8.1 on the phone again. WP 8.1 changed emmc driver CMD38 erase function and the changes are not compatible with the samsung emmc inside the phone. |
05-02-2015, 22:11 | #4 (permalink) | |||
Member: 103024 Status: Offline Thanks Meter: 616 | thanks for response , i just repaired boot using emmc conection as you advice , now phone is semi alive again here is repair log Quote:
and here is the log after some try , phone not acept flash files , is there any other thing to do ? i dont know wich firmware version contain windows 8.1 , maybe this was the problem on the first flash attemp Quote:
05-03-2015, 02:55 | #5 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @rogerboogie 1. Do not put 8.1 to recently Fixed Phone... You will kill eMMC Again. The flash file you used is not 8.1... but it is very very very old. TO Repair Phone, do following. 1. Connect via eMMC again and BACKUP 512MB of USER area to save IMEI etc. Use 15 Mhz so it will be fast. ( Less than 8 minutes ) 2. Take note of eMMC EXT_CSD file that is saved when you click SCAN EMMC. 3. Perform "Firmware Update + Format" 4. Write Back EXT_CSD File which saved earlier when you clicked "SCAN EMMC" Use "Write EXT_CSD Backup File" option in "Advance" section of eMMC Tool * Make sure you see this after you write EXT_CSD 15:37:15 : BOOT PARTITION : USER AREA 15:37:15 : PARTITION ACCESS : R/W USER PARTITION 15:37:15 : PERM_BOOT_CFG_PROT : DISABLED 15:37:15 : PWR_BOOT_CFG_PROT : DISABLED 15:37:15 : BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED 5. Repair BOOT again using same step you used via eMMC. 6. Remove eMMC Wires and Flash Phone via USB with battery that have more than 30% Charge. * ALL FILES for RM-915 in Navifirm are ALL 8.0. So download the latest/newest version and it will still be 8.0... 8.1 Officially comes from OTA for RM-915. |
05-05-2015, 22:45 | #7 (permalink) | |
Member: 103024 Status: Offline Thanks Meter: 616 | Sr , after several attemps of samsung firmaware update + format this is the problem that iam stuck Quote:
05-06-2015, 02:18 | #8 (permalink) |
Member: 103024 Status: Offline Thanks Meter: 616 | Take note about the name of emmc , now is 000000 , and dont have any other way to repair the name , can you give me instructions of what to do sr ? Thanks |
05-06-2015, 07:34 | #12 (permalink) |
Member: 103024 Status: Offline Thanks Meter: 616 | You pm inbox is full so i cannot send you by this way my whatsapp is +525524958894 my email [email protected] here is my contact info , feel free to contact me anytime , and i will have phone in hands for this week without problems thanks for your help |
09-05-2015, 12:04 | #13 (permalink) |
Junior Member Join Date: May 2012
Member: 1764616 Status: Offline Thanks Meter: 0 | Atf team To. ATF TEAM LUMIA 520 "rm914" Q1)Plzz provide me how to connect emmc test point to atf box means i want complete detail with digram on pcb where are points and main thing is that i have only usb cable and r45 cable "cat6" and i don't know anything q2)plzzz update new feature of repairing or removing emmc write protected via usb cable only direct method just connect usb cable to luimia 520 and remove emmc protected or repair |
