11-25-2014, 18:38 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | lumia 520 repair error Phone Type : Lumia 520 RM-914 CPU Type : Qualcomm MSM8227 Storage Type: eMMC 8GB Boot Package: 3056.40000.1408.0007 (BIG BOOT) ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Restore Boot... Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Restore Boot... Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! plz help |
11-26-2014, 09:20 | #3 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | yes bro i already try ffu flasher but same error please guide me |
The Following User Says Thank You to maanarman For This Useful Post: |
11-26-2014, 09:46 | #4 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @maanarman 1. Do not use battery 2. Make sure Orange T and Orange S are connected properly 3. First do no connect USB cable 4. When you start boot repair and software start to look for phone, then connect USB Cable. If all else still fails, then just shorten your wires and make sure you are using old FBUS cable and you are not USING LAN CABLE RJ-45 which you buy from PC Store. LAN Cable wires will not work for JTAG !! |
12-04-2014, 19:40 | #5 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: KABUPATEN SLEMAN
Member: 714648 Status: Offline Sonork: 1609640 Thanks Meter: 931 | Quote:
this FFU ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x4F1F0F0F IR4 Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004D3847325943004B01166E50B6 Flash Description: Samsung M8G2YC, 7.28 GiB, SN 4B01166E, May 1997 Flash Write Protection: PERM Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...Memory Write Error, Access to Memory Not Completed! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004D3847325943004B01166E50B6 Flash Description: Samsung M8G2YC, 7.28 GiB, SN 4B01166E, May 1997 Flash Write Protection: PERM Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (5954 Op/Sec) FFU File Loaded: RM914_3058.50000.1425.0004_RETAIL_apac_indonesia_2 05_04_447903_prd_signed.ffu FFU File CRC-32: Computing, Please wait...0x14C955A6 Analyzing FFU, please wait...OK Restoring MBR Data...OK Restoring GPT Data from Backup...OK Writing "SBL1" area, flash #1, p#0, 0x0001000000, 0x0000018C00...OK Writing "SBL2" area, flash #1, p#0, 0x0001200000, 0x000001E000...OK Writing "SBL3" area, flash #1, p#0, 0x0001400000, 0x0000054800...OK Writing "UEFI" area, flash #1, p#0, 0x0001600000, 0x0000101A00...OK Writing "RPM" area, flash #1, p#0, 0x0001A00000, 0x0000021000...OK Writing "TZ" area, flash #1, p#0, 0x0001C00000, 0x0000032200...OK Writing "WINSECAPP" area, flash #1, p#0, 0x0001E00000, 0x000004D400...OK Writing "PLAT" area, flash #1, p#0, 0x0003400000, 0x0000264800...OK Writing "EFIESP" area, flash #1, p#0, 0x0004000000, 0x00014A1C00...OK Writing "MMOS" area, flash #1, p#0, 0x0008C00000, 0x0004BD1000...OK Completed in 0h 5m 29s. Code Download Speed 314 KiB/sec. this fllashing Windows Phone 8/8.1 Flashing Started Loading Flash Files Please Wait... ================================================== ==== Windows Phone 8/8.1 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ================================================== ==== Nokia Phone Info Mode Initiated... Please wait upto 15 Seconds for SW Reset IMEI: 357287050562125 Version: 1.1.1.3 Product Code: 059S3Q0 Module Code: 0205435 Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00E90000 Block ID 0x05 : Nokia.MSM8227.P6036.1.2 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100030000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : SYNC + ASYNC Query Flash App Information... Flash App Information: 02010E011900 UEFI App: FLASH APP Flash App Protocol Version: 1.14 Flash App Implementation Version: 1.25 Query ROOT KEY HASH... ROOT_KEY_HASH: F771E62AF89994064F77CD3BC16829503BDF9A3D506D3FACEC AEF3F808C868FD Sending Image Signatures... ERROR: Flash Signature Block REJECTED! (0x11068000000E00000000) This Flash File is NOT COMPATIBLE with this Phone. ERROR: Flashing Failed! | |
