12-19-2013, 13:42 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Am In Wealth Always!
Member: 576282 Status: Offline Thanks Meter: 145 | Lumia 520 (RM-914) boot repair error? this phone can check complete but while trying to repair the boot, it gives error, please I will post the connection testing logs and the repair logs so that somebody will help me out to tell me what is going wrong on it EMMC Connection testing logs: ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V 1.9-2.0V CID : 1501004D38473259430019E55BD2 CSD : D02701320F5903FFF6DBFFEF96404063 eMMC Boot Information BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT: DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : M8G2YC Product Rev : 0.0 Product SN : 19E55BD2 Manufactured : June 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO EMMC Repair error logs: ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V 1.9-2.0V CID : 1501004D38473259430019E55BD2 CSD : D02701320F5903FFF6DBFFEF96404063 eMMC Boot Information BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT: DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : M8G2YC Product Rev : 0.0 Product SN : 19E55BD2 Manufactured : June 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Writing MBR + GPT... Write Success! Writing SBL1... Write Success! Writing SBL2... ERROR: Block Write Failed at 0x0000952A Check your Test Point Soldering! ERROR: WRITE FAILED! Total Elapsed Time 00:01:56 Please what else will I do on this because the owner is on my neck. Thanks. |
The Following 2 Users Say Thank You to lionfinger2007 For This Useful Post: |
12-27-2013, 15:35 | #2 (permalink) |
Freak Poster Join Date: Aug 2010 Location: Ukraine, Lutsk
Member: 1367150 Status: Offline Thanks Meter: 42 | Hello, About lumia 520 atf boot repair. Where you find test point for ATF.I need it, i found only atf Jtag tst point,it doesn't match(dont work). Please give picture of your soldering |
