07-02-2015, 07:31 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Lumia 610 not read unlock code JTAG Interface Connected, S/N 0xE261BF38 Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 08/07/2014 10:52:00 PM ================================================== ======== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported : Lumia 510 RM-889 - Supported : Lumia 510 RM-898 - Supported : Lumia 505 RM-923 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Power On Phone before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. DO NOT Connect a USB Cable to the phone 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect Phone BATTERY and POWER ON the Phone 5. Wait until WP7 OS is FULLY LOADED showing Main Menu 6. Check that Phone IMEI is valid via *#06# 7. If IMEI is valid, Click READ CODES button then wait... ---------------------------------------------------------- Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x106210E1 IR4 Loading AFP (Please Wait)...OK AFP revision 4, compiled 08/07/2014 10:52:00 PM ================================================== ======== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported : Lumia 510 RM-889 - Supported : Lumia 510 RM-898 - Supported : Lumia 505 RM-923 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Power On Phone before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. DO NOT Connect a USB Cable to the phone 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect Phone BATTERY and POWER ON the Phone 5. Wait until WP7 OS is FULLY LOADED showing Main Menu 6. Check that Phone IMEI is valid via *#06# 7. If IMEI is valid, Click READ CODES button then wait... ---------------------------------------------------------- Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x106210E1 IR4 Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...No Devices found in Chain! |
07-02-2015, 08:10 | #2 (permalink) |
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | ATF JTAG v1.0.15.8544 (17/06/2015) Default language ID 0x0409, LR 14 JTAG Interface Connected, S/N 0xE261BF38 Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 08/07/2014 10:52:00 PM ================================================== ======== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported : Lumia 510 RM-889 - Supported : Lumia 510 RM-898 - Supported : Lumia 505 RM-923 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Power On Phone before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. DO NOT Connect a USB Cable to the phone 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect Phone BATTERY and POWER ON the Phone 5. Wait until WP7 OS is FULLY LOADED showing Main Menu 6. Check that Phone IMEI is valid via *#06# 7. If IMEI is valid, Click READ CODES button then wait... ---------------------------------------------------------- Initializing Connection Connected 1 device(s)! Halting Core... Halted Device 0x106210E1 1. Disconnect USB Cable from Phone 2. Reconnect USB Cable to Phone 3. Wait for 20 Seconds <--- Very Important 4. Disconnect USB Cable from Phone 5. Click Read Codes Button Again Initializing Connection Connected 1 device(s)! Halting Core... Cannot Halt Core! Initializing Connection Connected 1 device(s)! Halting Core... Halted Device 0x106210E1 1. Disconnect USB Cable from Phone 2. Reconnect USB Cable to Phone 3. Wait for 20 Seconds <--- Very Important 4. Disconnect USB Cable from Phone 5. Click Read Codes Button Again Initializing Connection Connected 1 device(s)! Halting Core... Halted Device 0x106210E1 Searching for PIN/PUK Unlock Codes... Please wait for a while... Unlock Codes Not Found! All Done! |
07-02-2015, 08:25 | #3 (permalink) |
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | ATF JTAG v1.0.15.8544 (17/06/2015) Default language ID 0x0409, LR 14 JTAG Interface Connected, S/N 0xE261BF38 Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x106210E1 IR4 Loading AFP (Please Wait)...OK AFP revision 4, compiled 26/11/2013 10:48:00 AM ================================================== ======== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click READ CODES button to Start Reading Unlock Codes ---------------------------------------------------------- Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...Timeout During Operation! Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core with 300ms Delay...OK Initializing Device...OK Retrieving Unlock Codes...Unknown EFS2 Format Detected. Service Provider Codes Not Found. |
