02-20-2015, 07:18 | #1 (permalink) |
No Life Poster Join Date: Oct 2010 Location: colombo
Member: 1418524 Status: Offline Thanks Meter: 186 | lumia 520 Unable to find a bootable option error JTAG Interface Connected, S/N 0x94265DB0 Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 9/3/2014 2:26:00 PM ================================================== ======== Phone Type : Lumia 520, 520T, 525, 526 CPU Type : Qualcomm MSM8227 Storage Type: eMMC 8GB Procedure : WP8 FFU Flasher via JTAG More Info : http://www.advance-box.com/ffu_flasher/ ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004D38473259430068D8C00BA0FC Flash Description: Samsung M8G2YC, 7.28 GiB, SN 68D8C00B, Oct 1997 Flash Write Protection: PERM Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (5953 Op/Sec) FFU File Loaded: RM914_3056.40000.1408.0007_RETAIL_eu_spain_282_07_ 395393_prd_signed.ffu FFU File CRC-32: Computing, Please wait...0x95A13793 Analyzing FFU, please wait...OK Restoring MBR Data...OK Restoring GPT Data from Backup...OK Writing "SBL1" area, flash #1, p#0, 0x0001000000, 0x0000018C00...OK Writing "SBL2" area, flash #1, p#0, 0x0001200000, 0x000001E000...OK Writing "SBL3" area, flash #1, p#0, 0x0001400000, 0x0000054800...OK Writing "UEFI" area, flash #1, p#0, 0x0001600000, 0x0000101A00...OK Writing "RPM" area, flash #1, p#0, 0x0001A00000, 0x0000021000...OK Writing "TZ" area, flash #1, p#0, 0x0001C00000, 0x0000032200...OK Writing "WINSECAPP" area, flash #1, p#0, 0x0001E00000, 0x000004D400...OK Writing "PLAT" area, flash #1, p#0, 0x0003400000, 0x0000264800...OK Writing "EFIESP" area, flash #1, p#0, 0x0004000000, 0x00014A1800...OK Writing "MMOS" area, flash #1, p#0, 0x0008C00000, 0x0004BD1000...OK Completed in 0h 5m 23s. Code Download Speed 319 KiB/sec. Windows Phone 8/8.1 Flashing Started Loading Flash Files Please Wait... ================================================== ==== Windows Phone 8/8.1 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ================================================== ==== Nokia Phone Info Mode Initiated... Please wait upto 15 Seconds for SW Reset IMEI: 359965052309490 Version: 1.1.1.3 Product Code: 059S3W7 Module Code: 0205435 Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00E90000 Block ID 0x05 : Nokia.MSM8227.P6036.1.2 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100130000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 02010F011C00 UEFI App: FLASH APP Flash App Protocol Version: 1.15 Flash App Implementation Version: 1.28 Query ROOT KEY HASH... ROOT_KEY_HASH: F771E62AF89994064F77CD3BC16829503BDF9A3D506D3FACEC AEF3F808C868FD Sending Image Signatures... ERROR: Flash Signature Block REJECTED! (0x11068000000E00000000) This Flash File is NOT COMPATIBLE with this Phone. ERROR: Flashing Failed! |
02-20-2015, 10:55 | #2 (permalink) | |
Member: 1418524 Status: Offline Thanks Meter: 186 | Quote:
now try BIG_BOOT LUMIA_520_RM-914_BIG_BOOT ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501004D38473259430068D8C00B CSD : D02701320F5903FFF6DBFFEF96406007 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 512 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : M8G2YC Product Rev : 0.0 Product SN : 68D8C00B Manufactured : October 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: YES TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501004D38473259430068D8C00B_D192F7FE.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Start Writing 0x0002D369 Blocks at 0x00000000 Partition Selected: USER AREA Total Elapsed Time 00:02:36 Write Success! Windows Phone 8/8.1 Flashing Started Loading Flash Files Please Wait... ================================================== ==== Windows Phone 8/8.1 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ================================================== ==== Nokia Phone Info Mode Initiated... Please wait upto 15 Seconds for SW Reset IMEI: 359965052309490 Version: 1.1.1.3 Product Code: 059S3W7 Module Code: 0205435 Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00E90000 Block ID 0x05 : Nokia.MSM8227.P6036.1.2 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100130000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 02010F011C00 UEFI App: FLASH APP Flash App Protocol Version: 1.15 Flash App Implementation Version: 1.28 Query ROOT KEY HASH... ROOT_KEY_HASH: F771E62AF89994064F77CD3BC16829503BDF9A3D506D3FACEC AEF3F808C868FD Sending Image Signatures... ERROR: Flash Signature Block REJECTED! (0x11068000000E00000000) This Flash File is NOT COMPATIBLE with this Phone. ERROR: Flashing Failed! same problem | |
