08-19-2014, 10:04 | #1 (permalink) | ||
No Life Poster Join Date: May 2011 Location: ..:Inside UR Brain:.. Age: 34
Member: 1586370 Status: Offline Sonork: 100.1618206 Thanks Meter: 154 | Lumia 520 , Unable to find bootable option...!!! - (FFU Flashing via JTAG INSIDE!!!) with this latest big boot afp file Lumia 520 RM-914 [3056.40000.1408.0007] [BIG BOOT] but the phone is still showing Unable to find bootable option. Here is boot repair logs Quote:
08-19-2014, 12:14 | #5 (permalink) | |
Member: 1586370 Status: Offline Sonork: 100.1618206 Thanks Meter: 154 | I cant find same product code latest firmware... i have this firmware Quote:
08-19-2014, 12:44 | #7 (permalink) | |
Member: 1586370 Status: Offline Sonork: 100.1618206 Thanks Meter: 154 | Quote:
i am ready... give me preview of "FFU Flashing via JTAG" i have downloaded this firmware RM914_3046.0000.1329.2001_RETAIL_im_india_269_01_2 49010_prd_signed.ffu | |
08-19-2014, 13:38 | #8 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Hi, Download this new ATFJ.exe here: atfj.exe Download WIN8 Custom Read/Write here: LUMIA_WIN8_CUSTOM_READ_WRITE.afp Follow Steps I described in the pictures below. Make sure FFU File you use is 100% not corrupted and is 100% match to your product code! STEP 1 STEP 2 STEP 3 STEP 4 STEP 5 STEP 6 STEP 7 B.R. Last edited by Advance-Box; 08-26-2014 at 13:54. |
The Following 3 Users Say Thank You to Advance-Box For This Useful Post: |
08-19-2014, 15:07 | #10 (permalink) | ||
Member: 1586370 Status: Offline Sonork: 100.1618206 Thanks Meter: 154 | Thnx for the attention here... i have successfully flashed .FFU via Jtag as u said... here are the logs... Quote:
Error with ATF... Quote:
i tried as u said but the phone is still in the same condition... | ||
08-19-2014, 15:18 | #11 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @shaikh_shoeb50 Charge/Change battery. nothing else is wrong. See my logs, I did that on a completely erased eMMC ... so my phone does not even have IMEI etc... and it still flashes via USB. |
10-11-2014, 20:31 | #12 (permalink) |
Freak Poster Join Date: Jun 2009
Member: 1049259 Status: Offline Thanks Meter: 14 | Default language ID 0x0409 JTAG Interface Connected, S/N 0xA414EAC9 Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 9/3/2014 2:26:00 PM ================================================== ======== Phone Type : Lumia 520, 520T, 525, 526 CPU Type : Qualcomm MSM8227 Storage Type: eMMC 8GB Procedure : WP8 FFU Flasher via JTAG More Info : http://www.advance-box.com/ffu_flasher/ ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...90014A48384732640401008F5FC28090 Flash Description: Hynix H8G2d, 7.23 GiB, SN 008F5FC2, Aug 1997 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (5955 Op/Sec) FFU File Loaded: 4419E305_RM915_3058.50000.1424.0008_RETAIL_apac_au stralia_new_zealand_231_08_444751_prd_signed.ffu FFU File CRC-32: Computing, Please wait...0x4419E305 Analyzing FFU, please wait...OK Restoring MBR Data...OK Restoring GPT Data from Backup...OK Writing "SBL1" area, flash #1, p#0, 0x0001000000, 0x0000180000...OK Writing "SBL2" area, flash #1, p#0, 0x0001200000, 0x0000180000...OK Writing "SBL3" area, flash #1, p#0, 0x0001400000, 0x0000200000...OK Writing "UEFI" area, flash #1, p#0, 0x0001600000, 0x0000200000...OK Writing "RPM" area, flash #1, p#0, 0x0001A00000, 0x0000080000...OK Writing "TZ" area, flash #1, p#0, 0x0001C00000, 0x0000080000...OK Writing "WINSECAPP" area, flash #1, p#0, 0x0001E00000, 0x0000080000...OK Writing "PLAT" area, flash #1, p#0, 0x0003400000, 0x0000264000...OK Writing "EFIESP" area, flash #1, p#0, 0x0004000000, 0x0000973400...OK Writing "MMOS" area, flash #1, p#0, 0x0008C00000, 0x0004BC8000...OK Completed in 0h 9m 48s. Code Download Speed 167 KiB/sec. Windows Phone 8/8.1 Flashing Started Loading Flash Files Please Wait... ================================================== ==== Windows Phone 8/8.1 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ================================================== ==== Nokia Phone Info Mode Initiated... Please wait upto 15 Seconds for SW Reset Version: 1.1.1.3 Product Code: 059S559 Module Code: 0205437 Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00E74000 Block ID 0x05 : Nokia.MSM8227.P6036.1.2 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100130000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 02010F011C00 UEFI App: FLASH APP Flash App Protocol Version: 1.15 Flash App Implementation Version: 1.28 Query ROOT KEY HASH... ROOT_KEY_HASH: 7C81AABA97E4904DB782605A6C74A59480361E5A363337B2EF 5B8F925763110B Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... Finished Sending all DATA BLOCKS! Exiting FLASH Mode via REBOOT... Exit FLASH Mode Successful! Flashing Done! Total Flashing Time : 00:02:50 phone back too life thanks atf |
02-17-2015, 15:12 | #15 (permalink) |
Freak Poster Join Date: Sep 2012 Location: Loading! Age: 34
Member: 1813502 Status: Offline Sonork: 100.1623430 Thanks Meter: 182 | Hey there after completing these all procedure (I mean after restoring boot via jitg) when I am trying to flash as u say I try to flash via usb it is showing this errorhttp://i59.tinypic.com/33uvexu.jpg |
