06-11-2015, 18:43 | #1 (permalink) |
No Life Poster Join Date: May 2013 Location: In Core Of eMMC
Member: 1950912 Status: Offline Sonork: 100.1654643(Offline) Thanks Meter: 403 | Lumia 525 Dead Boot Repair Problem Tried Jtag but phone is not getting detect with software therefore decided to connect through Direct eMMC detect ok but unable to write .mmc file See log> Code: ====================================================== ====================================================== eMMC Test Point Connection Module ====================================================== ====================================================== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 90014A4838473264040100E6CA2F2163 CSD : D02701320F5903FFFFFFFFEF8A4040D3 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 7759462400 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 2048 KB eMMC Device Information Manufacturer ID: HYNIX Device Type : Embedded BGA Application ID : 4A Product Name : H8G2d Product Rev : 0.1 Product SN : 00E6CA2F Manufactured : January 1998 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 90014A4838473264040100E6CA2F2163.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ ====================================================== Loading ATF MMC File... (Please Wait) ====================================================== MMC File Version: v11.30 MMC File Author: 963F2A3CB175EDB4B4358C42 Date Created: 05/07/2014 (dd/mm/yyyy) Description: Lumia 525 RM-998 BIG BOOT V2 [3055.40000.1347.1008] Current Partition: Partition 1 Start Writing Blocks... R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! |
06-12-2015, 15:23 | #3 (permalink) |
Member: 1950912 Status: Offline Sonork: 100.1654643(Offline) Thanks Meter: 403 | Please reply me sir Advance-Box |
