10-27-2015, 13:53 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Hell
Member: 679176 Status: Offline Sonork: 1585224 Thanks Meter: 119 | Lumia 535 flash problem!!! Windows boot manager windows faild to start. A recemt hardware or software change might cause. To fix the problem: 1. Insert your windows installation disc and restart your computer. 2. Choose your language settings, and then click next. 3. Click repair your computer. If you dont have this disk contact your system administrator or manufacter for assistance. File:\efi\microsoft\boot\bcd status oxooooo34 info: The boot configuration data for your pc is missing or contains errors. Windows_key=uefi firmware settings. i try to repair via jtag. scan emmc ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 90014A483847316505034AE905452271 CSD : D02701320F5903FFFFFFFFEF8A4040D3 eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3072 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB eMMC Device Information Manufacturer ID: HYNIX Device Type : Embedded BGA Application ID : 4A Product Name : H8G1e Product Rev : 0.3 Product SN : 4AE90545 Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 90014A483847316505034AE905452271.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ if i try to write boot ================================================== ==== Loading ATF MMC File... (Please Wait) ================================================== ==== MMC File Version: v11.30 MMC File Author: 963F2A3CB175EDB4B4358C42 Date Created: 17/12/2014 (dd/mm/yyyy) Description: Lumia 535 RM-1089 BOOT [02048.00000.14457.51001] Current Partition: Partition 1 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 2 Start Writing Blocks... flash via usb Windows Phone 8/8.1/10 Flashing Started Loading Flash Files Please Wait... [DEAD BOOT REPAIR via USB is SUPPORTED] ================================================== ==== Windows Phone 8/8.1/10 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" Located at: C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\ ================================================== ==== Process Cancelled... Recovery Handle Found! - (Qualcomm) ERROR: Emergency Loader Sending Failed! ERROR CODE: 0x00000000 ERROR: Flashing Failed! Last edited by bighiner; 10-27-2015 at 14:02. |
10-27-2015, 13:59 | #2 (permalink) |
Member: 679176 Status: Offline Sonork: 1585224 Thanks Meter: 119 | if i try to flash via usb Windows Phone 8/8.1/10 Flashing Started Loading Flash Files Please Wait... [DEAD BOOT REPAIR via USB is SUPPORTED] ================================================== ==== Windows Phone 8/8.1/10 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" Located at: C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\ ================================================== ==== Recovery Handle Found! - (Qualcomm) ERROR: Emergency Loader Sending Failed! ERROR CODE: 0x00000000 ERROR: Flashing Failed! |
