06-07-2017, 06:16 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: JSR, BD
Member: 310155 Status: Offline Thanks Meter: 1,313 | Lumia 540DS RM-1141 dead boot during flash !! ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 90014A48384731650503CE70886352ED CSD : D02701320F5903FFFFFFFFEF8A4040D3 eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3072 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB eMMC Device Information Manufacturer ID: HYNIX Device Type : Embedded BGA Application ID : 4A Product Name : H8G1e Product Rev : 0.3 Product SN : CE708863 Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 90014A48384731650503CE70886352ED.ext_csd Backup Directory: H:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ ================================================== ==== Loading ATF MMC File... (Please Wait) ================================================== ==== MMC File Version: v12.31 MMC File Author: Date Created: 31/07/2015 (dd/mm/yyyy) Description: Microsoft Lumia 540 DS [RM-1141] - FULL BOOT - 02074.10000.15174.44002 Current Partition: Partition 1 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 2 Start Writing Blocks... Operation Cancelled... Total Elapsed Time 00:01:11 ERROR: WRITE FAILED! |
