07-08-2014, 16:17 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | <<<< LUMIA 610, 610C, 510 and 505 Unlock Method V3 BETA TESTERS NEEDED >>>> I am looking for BETA TESTERS for new Unlock Method for 610 etc via JTAG on a LIVE Phone. Qualifications: 1. You should have ATF JTAG Already Activated 2. You should be able to solder JTAG wires to the phone and still can POWER ON the phone even when the wires are still connected 3. You should have an actual locked phone to test. If you are interested, just post BOX SN here. This "New Method V3" should make is very easy to read codes from these WP7 phones now. B.R. |
The Following 6 Users Say Thank You to Advance-Box For This Useful Post: |
07-08-2014, 19:02 | #4 (permalink) |
No Life Poster Join Date: May 2006 Location: heLL and beY0nd
Member: 281801 Status: Offline Sonork: 100.1608672 Thanks Meter: 158 | I have 510 locked and 710 locked I unlock 710 with ATF Nitro without JTAG but i never activate AJTAG Module. I just bought the box this june 2014 but waiting for any Bonus Activation. I missed-out the LUMIA testing. Very disappointing ~~Keep it up Boss. You are the BEST. Just release the damn solution without testting, i know it will work. Pls dont forget LUMIA 8, that is the real BOMB |
07-08-2014, 19:26 | #6 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @ALL 1. Download ATFJ 1.0.10 build 4685 here: atfj.exe - 1.0.10 build 4685 --- Only this EXE version will work with new Method of 610 Read Codes 2. Download V3 AFP File 610_610C_510_505_UNLOCK_V3.afp You will see further instructions once you load V3 AFP file. 1. Make sure JTAG Connection is 100% OK 2. DO NOT Connect a USB Cable to the phone 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect Phone BATTERY and POWER ON the Phone 5. Wait until WP7 OS is FULLY LOADED showing Main Menu 6. Check that Phone IMEI is valid via *#06# 7. If IMEI is valid, Click READ CODES button then wait... |
07-08-2014, 20:14 | #9 (permalink) |
No Life Poster Join Date: May 2000 Location: Bacau, Romania Age: 50
Member: 1447 Status: Offline Thanks Meter: 97 | Default language ID 0x0409 JTAG Interface Connected, S/N 0x9E25B86F Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 7/8/2014 10:52:00 PM ================================================== ======== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported : Lumia 510 RM-889 - Supported : Lumia 510 RM-898 - Supported : Lumia 505 RM-923 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Power On Phone before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. DO NOT Connect a USB Cable to the phone 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect Phone BATTERY and POWER ON the Phone 5. Wait until WP7 OS is FULLY LOADED showing Main Menu 6. Check that Phone IMEI is valid via *#06# 7. If IMEI is valid, Click READ CODES button then wait... ---------------------------------------------------------- Initializing Connection Connected 1 device(s)! Halting Core... Halted Device 0x106210E1 Searching for PIN/PUK Unlock Codes... Please wait for a while... Codes Found! ========================= PIN LEVEL 1: 24524088 - LOCKED PUK LEVEL 1: 84132862 - LOCKED PIN LEVEL 2: 65201103 PUK LEVEL 2: 29272054 PIN LEVEL 3: 09181668 - LOCKED PUK LEVEL 3: 15790228 - LOCKED PIN LEVEL 4: 51588844 PUK LEVEL 4: 58110721 PIN LEVEL 5: 26880268 PUK LEVEL 5: 08677472 ========================= Reading Unlock Codes Done! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ================================================== ========================== All Done! ALL DONE !!!!! both code is working...need final version...GOOD JOB!!!! Last edited by DomnulV; 07-08-2014 at 20:22. |
07-09-2014, 07:58 | #11 (permalink) |
Member: 1447 Status: Offline Thanks Meter: 97 | NO...for me the test Is 100% working..... First method is not working and this method is 100% OK. This EXE is only for 610 new or is for all and new phone? |
07-09-2014, 08:06 | #12 (permalink) | |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
It should work on all known variants of 610, 610C, 510 and 505. I tested it on a 510 and 505. I cannot test on my 610 because I lost my 610 LCD a long time ago hehehe. Just make sure IMEI is correctly shown in *#06# before you click "Read Codes" button. | |
07-09-2014, 16:32 | #13 (permalink) |
Product Supporter Join Date: Jul 2010 Location: MobilesFactory,trichy,TN,India Age: 33
Member: 1347585 Status: Offline Sonork: 100.1596390 Thanks Meter: 467 | Hi Bro I have a lumia 900 Rm-808 locked phone i tried with 1.0.2 exe and also latest one too but halt error like this Code: ========================================================== Phone Type : Lumia 900 RM-808, RM-823 Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Automatic Counter Reset (If Needed) ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY Flex Cable 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect USB Cable to Phone 5. Use RESET JTAG button to check the JTAG Connection 6. Click RESTORE BOOT button to Start Reading Unlock Codes ---------------------------------------------------------- Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...Cannot Halt Core! or you have a any other files for test ? |
07-09-2014, 16:50 | #14 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @rajeshchiyyan No,, Lumia 900 is different... Check this: 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY Flex Cable 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect USB Cable to Phone 5. Use RESET JTAG button to check the JTAG Connection 6. Click RESTORE BOOT button to Start Reading Unlock Codes |
