05-28-2015, 15:46 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Romania,Buc
Member: 694535 Status: Offline Thanks Meter: 70 | lumia 610 auto vibrates when insert battery no power on i've tryed to unlock this lumia 610 rm_849 but didn't pass second part connection time out , after this phone doesn't power on when i insert battery phone vibrates and no power on ...... i resold jtag try to restore boot error again Default language ID 0x0409, LR 12 JTAG Interface Connected, S/N 0xA28BF7F0 Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 11/27/2013 1:43:00 PM ================================================== ======== Phone Type : Lumia 610 RM-835, RM-849 CPU Type : Qualcomm MSM7227A Storage TYpe: eMMC 8GB ================================================== ======= 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click RESTORE BOOT button to Start Operation ---------------------------------------------------------- Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...110100303038473442001B18872D6FCA Flash Description: Toshiba 008G4B, 7.41 GiB, SN 1B18872D, Jun 2012 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (114320 Op/Sec) Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...Flash Write Error at 0x00046A00, Bad Answer from Loader 0x0, 0x1304 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...110100303038473442001B18872D6FCA Flash Description: Toshiba 008G4B, 7.41 GiB, SN 1B18872D, Jun 2012 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (114294 Op/Sec) Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...Flash Write Error at 0x0002AA00, Bad Answer from Loader 0x0, 0x2204 solution ? |
