12-10-2014, 13:11 | #1 (permalink) |
Major Poster Join Date: Apr 2005 Age: 44
Member: 133116 Status: Offline Thanks Meter: 1 | Lumia 610 error boot repair Logs.............................. 6:20:00 : eMMC Boot Information 16:20:00 : Revision 1.5 (for MMC v4.41) 16:20:00 : BOOT PARTITION : USER AREA 16:20:00 : PARTITION ACCESS : R/W USER PARTITION 16:20:00 : PERM_BOOT_CFG_PROT : DISABLED 16:20:00 : PWR_BOOT_CFG_PROT : DISABLED 16:20:00 : BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED 16:20:00 : RESET BUS WIDTH : ENABLED 16:20:00 : eMMC FirmW UPDATE : DISABLED 16:20:00 : EMMC CACHE SIZE : 0 KB 16:20:00 : SUPER PAGE SIZE : 3584 KB 16:20:00 : HC ERASE GROUP SIZE: 4096 KB 16:20:00 : USER AREA SIZE : 7952400384 BYTES 16:20:00 : BOOT PARTITION SIZE: 2048 KB 16:20:00 : RPMB PARTITION SIZE: 256 KB 16:20:00 : 16:20:01 : Lumia 610/610C Detected 16:20:01 : 16:20:01 : eMMC Device Information 16:20:01 : Manufacturer ID: TOSHIBA 16:20:01 : Device Type : Embedded BGA 16:20:01 : Application ID : 00 16:20:01 : Product Name : 008G4B 16:20:01 : Product Rev : 0.0 16:20:01 : Product SN : 06100F1C 16:20:01 : Manufactured : January 2012 16:20:01 : 16:20:01 : Card Specific Data 16:20:01 : CSD_STRUCTURE : Extended 16:20:01 : SPEC_VERS : Version 4.1/4.2/4.3 16:20:01 : TAAC : 3 ns 16:20:01 : TRANS_SPEED : 4000000 KHz 16:20:01 : READ_BL_LEN : 512 Bytes 16:20:01 : C_SIZE : HIGH CAPACITY 16:20:01 : WP_GRP_ENABLE : YES 16:20:01 : WRITE_BL_LEN : 512 Bytes 16:20:01 : CONTENT_PROT_APP : NO 16:20:01 : PERM_WRITE_PROTECT: NO 16:20:01 : TMP_WRITE_PROTECT : NO 16:20:01 : 16:20:01 : Extended CSD Saved: 16:20:01 : 1101003030384734420006100F1C_CE0EBCEE.ext_csd 16:20:01 : Backup Directory: 16:20:01 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 16:20:01 : 16:20:01 : Writing MBR... 16:20:01 : Write Success! 16:20:01 : Writing DBL... 16:20:01 : Block Write CRC Error 16:20:01 : ERROR: Block Write Failed at 0x00000003 16:20:01 : Check your Test Point Soldering! 16:20:01 : ERROR: WRITE FAILED! |
12-10-2014, 14:40 | #5 (permalink) |
Member: 133116 Status: Offline Thanks Meter: 1 | Connected the phone to the system with battery inserted . The phone is neither vibrating nor getting switched on . But it is making usb connection sound and in the device manager it is showing under Universal Serial Bus Devices> QHSUSB_DLOAD. We are also attaching the image of Device manager. http://i1260.photobucket.com/albums/...k/610image.png |
