02-02-2013, 09:50 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: africa
Member: 586192 Status: Offline Thanks Meter: 66 | lumia 610 flashing pb |
02-02-2013, 10:21 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, You have to put boot-loader Nokia DLOAD through Test Point. After it will be flashable by any flasher or ATF software. BR |
02-03-2013, 13:17 | #7 (permalink) |
Member: 586192 Status: Offline Thanks Meter: 66 | 01:24:05 : 01:24:05 : ///////// /// /// /////// /////// ///////// 01:24:05 : /// /// /// /// // /// /// /// /// 01:24:05 : /// /// /// /////// /////// /// /// 01:24:05 : /// /// /// /// /// /// /// /// /// 01:24:05 : /// ///// /// /// /////// ////// 01:24:06 : 01:24:06 : ======================================= 01:24:06 : /// /// /// ///////// /////// ////// 01:24:06 : ///// /// /// /// /// // /// /// 01:24:06 : /// ///// /// /// /////// /// /// 01:24:06 : /// //// /// /// /// /// /// /// 01:24:06 : /// /// /// /// /// /// ////// 01:24:06 : ======================================= 01:24:06 : 01:24:37 : ================================================== ==== 01:24:37 : ================================================== ==== 01:24:37 : Lumia Test Point Connection Module 01:24:37 : ================================================== ==== 01:24:37 : ================================================== ==== 01:24:37 : 01:24:37 : 1. DO NOT USE THE PHONE"S BATTERY 01:24:37 : 2. Connect the Soldered TP Connections to ATF Box 01:24:37 : 3. Disconnect the USB Cable and Wait until the 01:24:37 : the ATF Software will tell you to Connect the USB. 01:24:37 : 01:24:40 : 01:24:40 : Interface Reset OK! 01:24:40 : Reading Platform Information... 01:24:40 : Selecting Active Handle... 01:24:40 : Select Handle OK! 01:24:40 : Sending Ping... 01:24:40 : Ping Reply OK! 01:24:40 : 01:24:40 : Lumia 610/610C Detected 01:24:40 : 01:24:40 : Storage Device Information 01:24:40 : Manufacturer ID: 11 01:24:40 : Application ID : 0100 01:24:40 : Product Name : 008G4B 01:24:40 : Product Rev : 00 01:24:40 : Product SN : 0C22960C 01:24:40 : 01:24:40 : Protection Information 01:24:40 : Write Protect A: OFF 01:24:40 : Write Protect B: OFF 01:24:40 : 01:24:40 : Writing OSBL... 01:25:28 : Write Success! 01:25:28 : 01:25:28 : BOOT Images Written Successfully! 01:25:28 : 01:25:28 : Total Elapsed Time 00:00:50 |
02-04-2013, 08:46 | #8 (permalink) |
Member: 586192 Status: Offline Thanks Meter: 66 | now i have this problem Windows Phone Flashing Started AMSS File Found: RM835_12w47_prod_generic_amss.esco WPOS File Found: RM835_12470_prod_263_01_boot.esco USER AREA ERASE File Found: RM835_12w47_prod_generic_user_area_erase.esco WARNING: OSBL File is not Loaded WARNING: MODEM ADSP File is not Loaded ================================================== ==== Windows Phone Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME UP button 2. Connect it to the USB Port while still Pressing the VOLUME UP button 3. Continue to Press the VOLUME UP button for 8 more seconds ================================================== ==== Sending AMSS Certificate HASH: 0A3B18ABC63D2CF5A23BEBC1500E56E22163B717 Certificate Size: 449 Bytes ERROR: Data Rejected at SEQ 0x3 Status : WRITE AMSS CERTIFICATE FAILED |
