07-15-2014, 11:19 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Age: 51
Member: 163099 Status: Offline Thanks Meter: 12 | Lumia 610 problems for fleshing Its me problems for fleshing Nokia Lumia 610 Windows Phone Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME UP button 2. Connect it to the USB Port while still Pressing the VOLUME UP button 3. Continue to Press the VOLUME UP button for 8 more seconds ================================================== ==== ERROR: Data Rejected at SEQ 0x1 ERROR: Data Rejected at SEQ 0x2 Sending AMSS Certificate HASH: 0A3B18ABC63D2CF5A23BEBC1500E56E22163B717 Certificate Size: 449 Bytes ERROR: Data Rejected at SEQ 0x3 Status : WRITE AMSS CERTIFICATE FAILED |
07-15-2014, 17:13 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @ar-tel Possible 2 problems that will cause this 1. Keystore is Bad 2. Battery is very LOW For number "2" problem, you can solve easy just by charging battery using external charger or another 610 phone. For number "1" problem, ATF does not support this kind of repair yet.... |
