03-18-2014, 12:14 | #1 (permalink) |
No Life Poster Join Date: Aug 2001 Location: Roma Age: 49
Member: 5926 Status: Offline Thanks Meter: 275 | Lumia 610 restore boot error. tried on many pc, different usb ports, tp soldered correctly, no watter dammage. It is first phone with this simptom. Phone is working, but not reading codes, only error, thats I said to write boot. and failed. Any solution please. |
03-18-2014, 12:22 | #2 (permalink) |
Member: 5926 Status: Offline Thanks Meter: 275 | Nevermind, Tried one more time and succeded. Code: Default language ID 0x0409 JTAG Interface Connected, S/N 0xED1D35F4 Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 11/27/2013 1:43:00 PM ========================================================== Phone Type : Lumia 610 RM-835, RM-849 CPU Type : Qualcomm MSM7227A Storage TYpe: eMMC 8GB ========================================================= 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click RESTORE BOOT button to Start Operation ---------------------------------------------------------- Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...Unk. 0x000000FE MMC08G, 7.28 GiB Testing Device Memory...OK Sending Flash Loader...OK Restoring Partition #1...OK Restoring Partition #2...Flash Write Error at 0x00000200, Loader Error, Code 0x72 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Init Write Error at line 3, Access to Memory Not Completed! Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...Unk. 0x000000FE MMC08G, 7.28 GiB Testing Device Memory...OK Sending Flash Loader...OK Restoring Partition #1...OK Restoring Partition #2...Flash Write Error at 0x00000200, Loader Error, Code 0x72 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...Unk. 0x000000FE MMC08G, 7.28 GiB Testing Device Memory...OK Sending Flash Loader...OK Restoring Partition #1...OK Restoring Partition #2...Flash Write Error at 0x00000200, Loader Error, Code 0x72 Loading AFP (Please Wait)...OK AFP revision 4, compiled 12/2/2013 10:01:00 AM ========================================================== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported : Lumia 510 RM-889 - Supported : Lumia 510 RM-898 - Supported : Lumia 505 RM-923 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click RESTORE BOOT button, then Connect USB Cable ---------------------------------------------------------- Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device... 1. Disconnect USB Cable from Phone 2. Reconnect USB Cable to Phone 3. Wait for 15 Seconds after First Vibration <--- Very Important 4. Disconnect USB Cable from Phone 5. Click RESTORE BOOT Button Again OK Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device... 1. Disconnect USB Cable from Phone 2. Reconnect USB Cable to Phone 3. Wait for 15 Seconds after First Vibration <--- Very Important 4. Disconnect USB Cable from Phone 5. Click RESTORE BOOT Button Again OK Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device... 1. Disconnect USB Cable from Phone 2. Reconnect USB Cable to Phone 3. Wait for 15 Seconds after First Vibration <--- Very Important 4. Disconnect USB Cable from Phone 5. Click RESTORE BOOT Button Again OK Loading AFP (Please Wait)...OK AFP revision 4, compiled 11/27/2013 1:43:00 PM ========================================================== Phone Type : Lumia 610 RM-835, RM-849 CPU Type : Qualcomm MSM7227A Storage TYpe: eMMC 8GB ========================================================= 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click RESTORE BOOT button to Start Operation ---------------------------------------------------------- Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...Unk. 0x000000FE MMC08G, 7.28 GiB Testing Device Memory...OK Sending Flash Loader...OK Restoring Partition #1...OK Restoring Partition #2...Flash Write Error at 0x00000200, Loader Error, Code 0x72 Saving "..\Logs\Screenshots\2014-03-18_13-10-49.jpg"...OK Loading AFP (Please Wait)...OK AFP revision 4, compiled 11/26/2013 10:48:00 AM ========================================================== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click READ CODES button to Start Reading Unlock Codes ---------------------------------------------------------- Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Retrieving Unlock Codes...OK =================================== Service Provider Unlock Codes Found =================================== Level 1 PIN: 01933570 ACTIVE Level 1 PUK: 93608790 ACTIVE Level 2 PIN: 97430265 Level 2 PUK: 95021739 Level 3 PIN: 87669313 Level 3 PUK: 24513125 Level 4 PIN: 99122019 Level 4 PUK: 46123354 Level 5 PIN: 63900597 Level 5 PUK: 34675847 =================================== Reading Unlock Codes Done! ============================================================================ 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ============================================================================ |
03-18-2014, 20:15 | #3 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, for next time - you don't have to Restore Boot for Reading Codes. Just need to select UNLOCK AFP and follow ATFJ.exe instructions. |
