05-18-2014, 19:20 | #1 (permalink) |
Insane Poster Join Date: Apr 2002
Member: 10994 Status: Offline Thanks Meter: 3 | Lumia 610 restore boot OK, but still Qualcomm HS-USB QDloader ... 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 0001001030184718320018842797 CSD : D00E00320F5903FFFFFFFFEF92400045 eMMC Boot Information Revision 1.6 (for MMC v4.5) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 4096 KB HC ERASE GROUP SIZE: 4096 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 512 KB eMMC Device Information Manufacturer ID: 00 Device Type : Embedded BGA Application ID : 00 Product Name : 0 G 2 Product Rev : 0.0 Product SN : 18842797 Manufactured : January 2004 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 3 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 0001001030184718320018842797_A4607940.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Writing MBR + GPT... Write Success! Writing SBL1... Write Success! Writing SBL2... Write Success! Writing SBL3... Write Success! Writing UEFI... Write Success! Writing RPM... Write Success! Writing TZ... Write Success! Writing WINSECAPP... Write Success! BOOT Images Written Successfully! Be sure to desolder all the wires properly before you try to flash the phone (if needed). Total Elapsed Time 00:11:58 |
