12-07-2013, 09:15 | #4 (permalink) |
Freak Poster Join Date: Feb 2012
Member: 1720169 Status: Offline Thanks Meter: 77 | here it is hey one more thing if your phone is 610nfc i.e rm 849 then the atf noov guys wont have emmc connection for that so for that you will need tp ATF jtag cost 39 $ activation and then restore boot option there but if its is 610 then the test point are in attchments named 610 rm835 not 849 in untitled.jpg you see that yellow box these are jtag points which are supported by ATF jtag only and 610 nfc rm849 will be repaired by these only IN TOTAL 610 NFC 849 CAN BE REPAIRED BY ATF JTAG ONLY IE 6 CONNECTION WALA 610 NFC 835 CAN BE REPAIRED BY BOTH 4 CONNECTION WALA AND 6 WALA |
12-07-2013, 11:04 | #5 (permalink) |
No Life Poster Join Date: Nov 2007 Location: United State Of Islam Age: 34
Member: 624551 Status: Offline Sonork: 100.1584837 Thanks Meter: 737 | now i have correct tp the 4 connection and giving this error and green is number 8 tp ...and i have cut the wire in the middle mean only 2 inches from cable |
12-08-2013, 06:39 | #10 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @ALL If Somebody has 610 NFC RM-849 on HAND, then take very very clear picture of entire PCB and I will show you where to solder the TP Pinouts. You need to make it really really clear, like using Galaxy Note 2/3 or iPhone 5 Camera. If the picture is not clear, then it will still be not clear to you. So help me to help you. B.R. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
