02-20-2015, 11:51 | #1 (permalink) |
Crazy Poster Join Date: Apr 2003 Location: Italy Age: 54
Member: 26663 Status: Offline Thanks Meter: 2 | Lumia 610 Rm-835 error partition n.3 I have this problem with Lumia 610 What type problem ? thanks Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1101003030384734420006D3EF047F6E Flash Description: Toshiba 008G4B, 7.41 GiB, SN 06D3EF04, Jul 2012 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (114878 Op/Sec) Restoring Partition #1...Skipped! Restoring Partition #2...Skipped! Restoring Partition #3...Flash Write Error at 0x0001D200, Bad Answer from Loader 0x3, 0x2904 Task Process Saved to: LUMIA_610_BOOT_REPAIR.task Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1101003030384734420006D3EF047F6E Flash Description: Toshiba 008G4B, 7.41 GiB, SN 06D3EF04, Jul 2012 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (114973 Op/Sec) Restoring Partition #1...Skipped! Restoring Partition #2...Skipped! Restoring Partition #3...Flash Write Error at 0x0001D200, Bad Answer from Loader 0x3, 0x5A04 Task Process Saved to: LUMIA_610_BOOT_REPAIR.task Loading AFP (Please Wait)...OK AFP revision 4, compiled 03/12/2013 20:44:00 ================================================== ======== Other Notes : Power On Phone before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. DO NOT Connect a USB Cable to the phone 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect Phone BATTERY and POWER ON the Phone 5. Wait until WP7 OS is FULLY LOADED showing Main Menu 6. Check that Phone IMEI is valid via *#06# 7. If IMEI is valid, Click READ CODES button then wait... ---------------------------------------------------------- Loading AFP (Please Wait)...OK AFP revision 4, compiled 27/11/2013 13:44:00 ================================================== ======== Phone Type : Lumia 610C RM-836 CPU Type : Qualcomm MSM7627A Storage TYpe: eMMC 8GB ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click RESTORE BOOT button to Start Operation ---------------------------------------------------------- Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1101003030384734420006D3EF047F6E Flash Description: Toshiba 008G4B, 7.41 GiB, SN 06D3EF04, Jul 2012 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (114885 Op/Sec) Restoring Partition #1...Flash Write Error at 0x00000000, Bad Answer from Loader 0x0, 0x904 Task Process Saved to: LUMIA_610C_BOOT_REPAIR.task Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1101003030384734420006D3EF047F6E Flash Description: Toshiba 008G4B, 7.41 GiB, SN 06D3EF04, Jul 2012 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (114787 Op/Sec) Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...Flash Write Error at 0x00021200, Bad Answer from Loader 0x0, 0x4F04 Task Process Saved to: LUMIA_610C_BOOT_REPAIR.task Saving "..\Logs\Screenshots\2015-02-19_23-25-28.jpg"...OK |
