Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 08-16-2016, 17:36   #1 (permalink)
Member: 1527968
Sonork: 100.1651182
Thanks Meter: 483
lumia 610 rm-835 unlock problam
Phone Type : Lumia 610 RM-835 - Supported
: Lumia 610 RM-849 - Supported
: Lumia 610C RM-836 - Supported
Unlock Type : Read PIN and PUK Unlock Codes
Other Notes : Disconnect USB Cable before Reading Codes
1. Make sure JTAG Connection is 100% OK
2. Always Disconnect the Phone BATTERY
3. Connect RJ-45 JTAG Cable to ATF Box
4. Disconnect USB Cable from the Phone
5. DO NOT click RESET JTAG button
6. Click READ CODES button to Start Reading Unlock Codes
Disconnect USB Cable from Phone (If Connected)
Re-Connect USB Cable to Phone...
Connect USB Cable to Phone...OK
USB Connected! Waiting for First Event...OK
Disconnect USB Cable Now...OK
Waiting for Device Connection 10 second(s)...Timeout During Operation!
Old 08-16-2016, 17:37   #2 (permalink)
Member: 1527968
Sonork: 100.1651182
Thanks Meter: 483
ATF JTAG v1.0.15.8544 (6/17/2015)
Default language ID 0x0409, LR 14
JTAG Interface Connected, S/N
Resetting and Exploring JTAG chain...No Devices found in Chain!
Loading AFP (Please Wait)...OK
AFP revision 4, compiled 11/26/2013 10:48:00 AM
Old 08-17-2016, 05:35   #3 (permalink)
Member: 1527968
Sonork: 100.1651182
Thanks Meter: 483
any idia plzzzzzzzzzzzzzzzz
Old 08-17-2016, 06:24   #4 (permalink)
Member: 1527968
Sonork: 100.1651182
Thanks Meter: 483
problam solve with chang fbus cable
Waiting for Device Connection 10 second(s)...OK
Resetting and Exploring JTAG chain...OK
Halting Core with 300ms Delay...OK
Initializing Device...OK
Retrieving Unlock Codes...OK
Service Provider Unlock Codes Found
Level 1 PIN: 95804796 ACTIVE
Level 1 PUK: 81083304 ACTIVE
Level 2 PIN: 44842712
Level 2 PUK: 04309186
Level 3 PIN: 08165888
Level 3 PUK: 45403331
Level 4 PIN: 37238311
Level 4 PUK: 63917445
Level 5 PIN: 81168065
Level 5 PUK: 47241853
Reading Unlock Codes Done!
1. Remove JTAG Connection and Assemble Phone
2. Insert SIM Card from different Provider into the Phone
3. Power ON the Phone
4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it
5. After Code is accepted, wait 30 seconds until Operator Signal Appears
Write Down 8-digit PIN CODE on a piece of paper and attach
it to the phone under the battery. This will allow the owner
of the phone to unlock this phone again if he will flash the
phone firmware in the future.
JTAG Interface Disconnected!
Page generated in 0.13909 seconds with 8 queries
