12-03-2013, 12:22 | #4 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @ecsike @THE BRAND Solution is Super Simple and y you can solve it. 1. Make sure you soldered to correct TP. (Make sure you did not use eMMC TP and that you are 100% Sure you are using JTAG TP) 2. Make sure you installed all Lumia Drivers and you PC can flash Lumia Phones with ATF Software. If you are still having problems, then you need to re-check your soldering work. Phone will never be detected if your soldering work or your wires are not correct. Use OLD FBUS Cable and make sure wire length is less than 6 inches total. |
12-03-2013, 14:40 | #6 (permalink) |
No Life Poster Join Date: May 2001 Location: Serbia Age: 42
Member: 4597 Status: Offline Thanks Meter: 36 | Unlock work, but instruction not GOOD!!! 1. Select Phone "610_610C_510_505_ALL_LEVELS_UNLOCK_V2.afp" 2. Connect JTags Rj45 cable to box 3. Push "RESTORE BOOT" 4. Now connect USB Cable and wait and do not Disconnect USB Cable!!! |
The Following User Says Thank You to ecsike For This Useful Post: |
