01-20-2015, 21:40 | #1 (permalink) |
Freak Poster Join Date: Aug 2009 Location: nobody is perfect and i'm 1
Member: 1105427 Status: Offline Sonork: I don't use sonork Thanks Meter: 57 | lumia 610 unlocking Timeout during operation am really loosing my mind over this fone .. am doing this on windows7 32-bit operating system Default language ID 0x0409 JTAG Interface Connected, S/N 0xFxxxxxxx Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 11/26/2013 10:48:00 AM ================================================== ======== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click READ CODES button to Start Reading Unlock Codes ---------------------------------------------------------- Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...Timeout During Operation! |
02-03-2015, 20:17 | #2 (permalink) |
Freak Poster Join Date: Jun 2009
Member: 1049259 Status: Offline Thanks Meter: 14 | Default language ID 0x0409 JTAG Interface Connected, S/N 0xA414EAC9 Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 7/8/2014 10:52:00 PM ================================================== ======== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported : Lumia 510 RM-889 - Supported : Lumia 510 RM-898 - Supported : Lumia 505 RM-923 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Power On Phone before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. DO NOT Connect a USB Cable to the phone 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect Phone BATTERY and POWER ON the Phone 5. Wait until WP7 OS is FULLY LOADED showing Main Menu 6. Check that Phone IMEI is valid via *#06# 7. If IMEI is valid, Click READ CODES button then wait... ---------------------------------------------------------- Initializing Connection Timeout During Operation! Initializing Connection Connected 1 device(s)! Halting Core... Halted Device 0x106210E1 Searching for PIN/PUK Unlock Codes... Please wait for a while... Codes Found! ========================= PIN LEVEL 1: 89713198 - LOCKED PUK LEVEL 1: 06273338 - LOCKED PIN LEVEL 2: 73956391 PUK LEVEL 2: 73503104 PIN LEVEL 3: 41153768 PUK LEVEL 3: 67471741 PIN LEVEL 4: 48512886 PUK LEVEL 4: 52313779 PIN LEVEL 5: 76418303 PUK LEVEL 5: 27610594 ========================= Reading Unlock Codes Done! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ================================================== ========================== All Done! |
