05-26-2014, 15:14 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: bangladesh, chittagong
Member: 648453 Status: Offline Thanks Meter: 82 | Lumia 620 downgrad when i search senior advice to flash this version RM846_1030.5603.1304.0000_RETAIL_eu_euro1_00_13277 1_prd_signed.ffu AND RM846_3046.0000.1329.2001_RETAIL_im_india_233_01_2 49122_prd_signed.ffu but flashing fail Windows Phone 8 Flashing Started Loading Flash Files Please Wait... ================================================== ==== Windows Phone 8 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ================================================== ==== Version: 1.1.1.3 Product Code: 059R6J8 Module Code: 0205404 Boot Flash Mode Successful... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00E74000 Block ID 0x05 : Nokia.MSM8227.P5122.1.2 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100030000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : SYNC + ASYNC Query Flash App Information... Flash App Information: 02010E011900 UEFI App: FLASH APP Flash App Protocol Version: 1.14 Flash App Implementation Version: 1.25 Query ROOT KEY HASH... ROOT_KEY_HASH: 67131691EEDD1F38568C7FFAE284FB2621680FEAC833314467 E31DAA963D1467 Sending Image Signatures... Image Signatures Accepted! Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... ERROR: DATA BLOCK REJECTED at 0x0B040000 Check your Flash File and Phone Connection ERROR: Flashing Failed! flash done by this version but not solved touch , i changed touch but same no luck RM846_3056.40000.1404.0002_RETAIL_im_mea3_237_02_3 85050_prd_signed.ffu Windows Phone 8 Flashing Started Loading Flash Files Please Wait... ================================================== ==== Windows Phone 8 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ================================================== ==== Version: 1.1.1.2 Product Code: 059R6J8 Module Code: 0205404 Boot Flash Mode Successful... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00E74000 Block ID 0x05 : Nokia.MSM8227.P5122.1.2 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100030000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : SYNC + ASYNC Query Flash App Information... Flash App Information: 020109011000 UEFI App: FLASH APP Flash App Protocol Version: 1.9 Flash App Implementation Version: 1.16 Query ROOT KEY HASH... ROOT_KEY_HASH: 67131691EEDD1F38568C7FFAE284FB2621680FEAC833314467 E31DAA963D1467 Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Fixing Partitions... Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... Finished Sending all DATA BLOCKS! Exiting FLASH Mode via REBOOT... Exit FLASH Mode Successful! Flashing Done! Total Flashing Time : 00:06:47 please help |
05-26-2014, 17:42 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Looks like your flash file for version 1xxx is corrupted. Download file again and flash. However, I am not sure about your problem that touch work for few seconds and than stops working. This could be hardware fault as well, if touch version do not match than it should not work at all... |
