04-26-2013, 16:13 | #1 (permalink) | ||
Freak Poster Join Date: May 2009
Member: 1032614 Status: Offline Thanks Meter: 46 | lumia 620 flashing Quote:
now phone condition is only vibrate when press power. what was the wrong? and how to revive it? full log.. Quote:
04-26-2013, 16:57 | #2 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | 17:14:06 : Start Sending DATA BLOCKS... 17:14:09 : ERROR: DATA BLOCK REJECTED! 17:14:09 : Check your Flash File and Phone Connection 17:14:09 : ERROR: Flashing Failed! Check flash file ( select other or download new file ) For flashing follow this as mention 17:17:33 : If the Phone is DEAD 17:17:33 : 1. Connect Phone to the USB Port 17:17:33 : 2. Press and Hold the VOLUME DOWN and POWER Buttons 17:17:33 : 3. Wait until the Phone Vibrates Shortly... 17:17:33 : 4. Stop Pressing the Buttons... Br - srinibas |
The Following User Says Thank You to srinibas For This Useful Post: |
04-26-2013, 18:54 | #3 (permalink) | |
Member: 1032614 Status: Offline Thanks Meter: 46 | Quote:
thanks for reply regards. | |
04-27-2013, 00:58 | #4 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @fudagsm From your logs I can see that flash file is corrupted. Where did you download this flash file and why didn't you download the 1 kb vpl file for it so that checksum could be verified? Anyway, please download correct flash file and come Monday I will have solution for your phone. Make sure you doqnload the VPL file as well. Never flash Lumia win 8 phones with unverified flash files. B.R. |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
04-27-2013, 05:33 | #5 (permalink) | ||
i downloaded this file from navifirm. i also downloaded vpl also Quote:
ok i am waiting for ur help regards. | ||
01-15-2014, 10:43 | #7 (permalink) |
No Life Poster Join Date: Feb 2009 Location: Ghaziabad, India
Member: 977479 Status: Offline Sonork: 100.1638508 Thanks Meter: 795 | my atf nitro says currently not supported for windows phone what does it means??? lumia 620 is hang on nokia logo what should I do??? |
01-15-2014, 11:16 | #8 (permalink) |
Member: 977479 Status: Offline Sonork: 100.1638508 Thanks Meter: 795 | Lumia 620 hang on nokia done via atf Code: Windows Phone 8 Flashing Started Loading Flash Files Please Wait... ====================================================== Windows Phone 8 Lumia Flasher ====================================================== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ====================================================== IMEI: 356347051752496 Version: 1.1.1.3 Product Code: 059R5S6 Module Code: 0205404 Boot Flash Mode Successful... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00E74000 Block ID 0x05 : Nokia.MSM8227.P5122.1.2 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100030000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : SYNC + ASYNC Query Flash App Information... Flash App Information: 02010C011700 UEFI App: FLASH APP Flash App Protocol Version: 1.12 Flash App Implementation Version: 1.23 Query ROOT KEY HASH... ROOT_KEY_HASH: 67131691EEDD1F38568C7FFAE284FB2621680FEAC833314467E31DAA963D1467 Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... Finished Sending all DATA BLOCKS! Exiting FLASH Mode via REBOOT... Exit FLASH Mode Successful! Flashing Done! Total Flashing Time : 00:03:34 |
10-10-2014, 10:58 | #9 (permalink) | |
Freak Poster Join Date: Oct 2006 Location: Earth Age: 36
Member: 380370 Status: Offline Sonork: 1601470 Thanks Meter: 52 | Quote:
10-10-2014, 13:18 | #10 (permalink) | |
Member: 977479 Status: Offline Sonork: 100.1638508 Thanks Meter: 795 | Quote:
If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... | |
