11-12-2013, 12:13 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, what is the problem in phone? Are you sure you are flashing phone with correct RM-XXX files ??? Try flashing with v1030.xxxx.xxxx files. BR |
12-31-2013, 23:38 | #3 (permalink) |
No Life Poster Join Date: Sep 2005 Age: 41
Member: 185279 Status: Offline Thanks Meter: 43 | Hi have the same problem. My Lumia 620 have a touch screen fail after update. But I can't flash it with ATF: ================================================== ==== Windows Phone 8 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ================================================== ==== IMEI: xxxxxxxxxxxxxxx Version: 1.1.1.3 Product Code: 059S2D8 Module Code: 0205404 Boot Flash Mode Successful... Phone Info Query Start... Blocks Returned: 0x02 Blocks Block ID 0x01 : 00241000 Block ID 0x04 : 010E0119 Checking SD Card Size... Card Size: 0x00040004 Checking Platform Security Status... Platform Secure Boot Status: Not Active Secure FFU EFUSE Status: Not Active Debug Status: Not Active RDC Status: Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : NONE Query Flash App Information... Flash App Information: 00040004010E01196F542072756F626F Flash App Protocol Version: 4.0 Flash App Implementation Version: 4.1 Query ROOT KEY HASH... ROOT_KEY_HASH: 00040004010E01196F542072756F626F ERROR: Flash File ROOT_KEY_HASH Mismatch! This Flash File is NOT COMPATIBLE with this Phone. ERROR: Flashing Failed! The file is RM846_1030.6407.1308.0002_RETAIL_lta_lta_381_02_18 6944_prd_signed.ffu The phone is RM-846 and the flash is for RM-846 How can I flash it ? Thank you. |
01-01-2014, 01:04 | #5 (permalink) |
Member: 185279 Status: Offline Thanks Meter: 43 | I tried again: ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ================================================== ==== Boot Flash Mode Successful... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00E74000 Block ID 0x05 : Nokia.MSM8227.P5122.1.2 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100030000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : SYNC + ASYNC Query Flash App Information... Flash App Information: 02010E011900 UEFI App: FLASH APP Flash App Protocol Version: 1.14 Flash App Implementation Version: 1.25 Query ROOT KEY HASH... ROOT_KEY_HASH: 67131691EEDD1F38568C7FFAE284FB2621680FEAC833314467 E31DAA963D1467 Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... Finished Sending all DATA BLOCKS! Exiting FLASH Mode via REBOOT... Exit FLASH Mode Successful! Flashing Done! Total Flashing Time : 00:03:32 My Lumia 620 is working now... |
01-30-2014, 13:07 | #6 (permalink) |
Freak Poster Join Date: Jan 2004 Location: EU Age: 50
Member: 48795 Status: Offline Thanks Meter: 21 | Windows Phone 8 Flashing Started Loading Flash Files Please Wait... ================================================== ==== Windows Phone 8 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ================================================== ==== Version: 1.1.1.3 Product Code: 059S036 Module Code: 0205404 Boot Flash Mode Successful... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00E74000 Block ID 0x05 : Nokia.MSM8227.P5122.1.2 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100030000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : SYNC + ASYNC Query Flash App Information... Flash App Information: 02010C011700 UEFI App: FLASH APP Flash App Protocol Version: 1.12 Flash App Implementation Version: 1.23 Query ROOT KEY HASH... ROOT_KEY_HASH: 67131691EEDD1F38568C7FFAE284FB2621680FEAC833314467 E31DAA963D1467 Sending Image Signatures... ERROR: Flash Signature Block REJECTED! This Flash File is NOT COMPATIBLE with this Phone. ERROR: Flashing Failed! Phone is after repair boot via jtag. What can i do for flash it correctly. I wrote all parts of boor via jtag but i can't flash it via ATF and Infinty Best. |
05-15-2014, 22:42 | #8 (permalink) |
Product Supporter Join Date: Dec 2010 Location: Brazil Fortaleza Ceará
Member: 1474113 Status: Offline Sonork: 100.1604217 Thanks Meter: 472 | I'm with two Lumia naminha Store was just update the device now is no more than 21% in atuialização already moved to several vesoes and the error still error what should I do? already formatted my pc is my ATF? |
07-17-2014, 06:41 | #9 (permalink) |
Freak Poster Join Date: Sep 2011 Location: saharanpur
Member: 1661299 Status: Offline Sonork: 100.1622657 Thanks Meter: 31 | Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x00 Blocks Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Not Active Secure FFU EFUSE Status: Not Active Debug Status: Not Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Not Active Checking Secure FFU Mode... Secure FFU Mode : NONE Query Flash App Information... Flash App Information: Flash App Protocol Version: 0.0 Flash App Implementation Version: 0.0 Query ROOT KEY HASH... ROOT_KEY_HASH: ERROR: Flash File ROOT_KEY_HASH Mismatch! This Flash File is NOT COMPATIBLE with this Phone. Select "Skip HW ID Chk" if you want to Flash this Phone with selected Flash Files Exiting FLASH Mode via REBOOT... Exit FLASH Mode Successful! Flashing Done! Total Flashing Time : 00:00:01 |
