05-07-2015, 16:25 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | Lumia 625 Unable to find a bootable option ERROR: Unable to find a bootable option. Press any key to shut down. i try to repaire boot by ffu flash but i see this error D 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004D384732594300CCFB5B1B70E8 Flash Description: Samsung M8G2YC, 7.28 GiB, SN CCFB5B1B, Jul 1997 Flash Write Protection: PERM Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (5904 Op/Sec) FFU File Loaded: RM941_3058.50000.1445.1007_RETAIL_eu_italy_221_07_ 458887_prd_signed.ffu FFU File CRC-32: Computing, Please wait...File Read Error 0x00000000 i download the same product code any idea please. thxxx |
05-07-2015, 16:37 | #2 (permalink) |
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | itry to flash If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" ================================================== ==== Nokia Phone Info Mode Initiated... Please wait upto 15 Seconds for SW Reset IMEI: 356689053988325 Version: 1.1.1.3 Product Code: 059T186 Module Code: 0205628 Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00E90000 Block ID 0x05 : Nokia.MSM8930.P6083.1.2 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100130000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 02010F011B00 UEFI App: FLASH APP Flash App Protocol Version: 1.15 Flash App Implementation Version: 1.27 Query ROOT KEY HASH... ROOT_KEY_HASH: 106D7E7DDC685B6E693326851A5DDACB7326B0297995A5BE00 3F724DEAE04EF2 Query PUBLIC ID... PUBLIC_ID: 805C3C954AC10115FC12C6377A8CA49B1C552C50 Query eMMC Info... EMMC Manufacture ID: SAMSUNG EMMC Product SN : CCFB5B1B EMMC_SIZE: 8 Gigabytes Query Battery Charge Status... BATTERY CHARGE_STATUS: 94% Sending Image Signatures... ERROR: Flash Signature Block REJECTED! (0x11068000000E00000000) This Flash File is NOT COMPATIBLE with this Phone. ERROR: Flashing Failed! |
05-07-2015, 16:41 | #3 (permalink) |
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | from here i download the flash file Free Download Firmwares Nokia Lumia 625 RM-941 Product Code 059T186 MrCrab.Net |
05-08-2015, 00:41 | #4 (permalink) |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Write Big Boot Via Atf Jtag Then Flash Your Phone & Post Result....... |
The Following User Says Thank You to hitech care For This Useful Post: |
05-08-2015, 08:12 | #5 (permalink) | |
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | Quote:
Nokia Phone Info Mode Initiated... Please wait upto 15 Seconds for SW Reset IMEI: 356689053988325 Version: 1.1.1.3 Product Code: 059T186 Module Code: 0205628 Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00E90000 Block ID 0x05 : Nokia.MSM8930.P6083.1.2 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100130000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 02010F011B00 UEFI App: FLASH APP Flash App Protocol Version: 1.15 Flash App Implementation Version: 1.27 Query ROOT KEY HASH... ROOT_KEY_HASH: 106D7E7DDC685B6E693326851A5DDACB7326B0297995A5BE00 3F724DEAE04EF2 Query PUBLIC ID... PUBLIC_ID: 805C3C954AC10115FC12C6377A8CA49B1C552C50 Query eMMC Info... EMMC Manufacture ID: SAMSUNG EMMC Product SN : CCFB5B1B EMMC_SIZE: 8 Gigabytes Query Battery Charge Status... BATTERY CHARGE_STATUS: 88% Sending Image Signatures... ERROR: Flash Signature Block REJECTED! (0x11068000000E00000000) This Flash File is NOT COMPATIBLE with this Phone. ERROR: Flashing Failed! | |
10-29-2015, 22:27 | #11 (permalink) | |
Freak Poster Join Date: Jan 2014 Location: ADUM PZ,KUMASI
Member: 2117988 Status: Offline Sonork: 100.1667932 Thanks Meter: 44 | emmc write protection problem Quote:
10-30-2015, 13:11 | #12 (permalink) | |
Freak Poster Join Date: Nov 2008 Location: türkey AKSARAY
Member: 897899 Status: Offline Thanks Meter: 36 | Quote:
