12-02-2015, 10:17 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Location: 5AAB Age: 37
Member: 167191 Status: Offline Thanks Meter: 363 | LUMIA 625 unable to find bootable SUCCESS with emmc READING with emmc tp Code: 14:26:55 : ====================================================== 14:26:55 : eMMC Test Point Connection Module 14:26:55 : ====================================================== 14:26:55 : ====================================================== 14:26:55 : 14:26:55 : 1. DO NOT USE THE PHONE"S BATTERY 14:26:55 : 2. Connect the Soldered TP Connections to ATF Box 14:26:55 : 3. Disconnect the USB Cable and Wait until the 14:26:55 : the ATF Software will tell you to Connect the USB. 14:26:55 : 14:26:55 : 14:26:55 : Interface Reset OK! 14:26:55 : eMMC Access Type: SECTOR MODE 14:26:55 : eMMC Supported Voltage Range: 14:26:55 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 14:26:55 : 14:26:55 : CID : 1501004D384732594300308FBC6C90D7 14:26:55 : CSD : D02701320F5903FFF6DBFFEF96406007 14:26:55 : 14:26:55 : eMMC Boot Information 14:26:55 : Revision 1.5 (for MMC v4.41) 14:26:55 : BOOT PARTITION : USER AREA 14:26:55 : PARTITION ACCESS : R/W USER PARTITION 14:26:55 : PERM_BOOT_CFG_PROT : DISABLED 14:26:55 : PWR_BOOT_CFG_PROT : DISABLED 14:26:55 : BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED 14:26:55 : RESET BUS WIDTH : ENABLED 14:26:55 : eMMC FirmW UPDATE : DISABLED 14:26:55 : EMMC CACHE SIZE : 0 KB 14:26:55 : SUPER PAGE SIZE : 3584 KB 14:26:55 : HC ERASE GROUP SIZE: 512 KB 14:26:55 : USER AREA SIZE : 7818182656 BYTES 14:26:55 : BOOT PARTITION SIZE: 4096 KB 14:26:55 : RPMB PARTITION SIZE: 512 KB 14:26:55 : 14:26:55 : 14:26:55 : eMMC Device Information 14:26:55 : Manufacturer ID: SAMSUNG 14:26:55 : Device Type : Embedded BGA 14:26:55 : Application ID : 00 14:26:55 : Product Name : M8G2YC 14:26:55 : Product Rev : 0.0 14:26:55 : Product SN : 308FBC6C 14:26:55 : Manufactured : September 1997 14:26:55 : 14:26:55 : Card Specific Data 14:26:55 : CSD_STRUCTURE : Extended 14:26:55 : SPEC_VERS : Version 4.1/4.2/4.3 14:26:55 : TAAC : 13 ns 14:26:55 : TRAN_SPEED : 4000000 KHz 14:26:55 : READ_BL_LEN : 512 Bytes 14:26:55 : C_SIZE : HIGH CAPACITY 14:26:55 : WP_GRP_ENABLE : YES 14:26:55 : WRITE_BL_LEN : 512 Bytes 14:26:55 : CONTENT_PROT_APP : NO 14:26:55 : PERM_WRITE_PROTECT: YES 14:26:55 : TMP_WRITE_PROTECT : NO 14:26:56 : 14:26:56 : Extended CSD Saved: 14:26:56 : 1501004D384732594300308FBC6C90D7.ext_csd 14:26:56 : Backup Directory: 14:26:56 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Dumping 512mb of user area Code: ====================================================== 14:27:08 : eMMC Test Point Connection Module 14:27:08 : ====================================================== 14:27:08 : ====================================================== 14:27:08 : 14:27:08 : 1. DO NOT USE THE PHONE"S BATTERY 14:27:08 : 2. Connect the Soldered TP Connections to ATF Box 14:27:08 : 3. Disconnect the USB Cable and Wait until the 14:27:08 : the ATF Software will tell you to Connect the USB. 14:27:08 : 14:27:08 : 14:27:08 : Interface Reset OK! 14:27:08 : eMMC Access Type: SECTOR MODE 14:27:08 : eMMC Supported Voltage Range: 14:27:08 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 14:27:08 : 14:27:08 : CID : 1501004D384732594300308FBC6C90D7 14:27:08 : CSD : D02701320F5903FFF6DBFFEF96406007 14:27:08 : 14:27:08 : eMMC Boot Information 14:27:08 : Revision 1.5 (for MMC v4.41) 14:27:08 : BOOT PARTITION : USER AREA 14:27:08 : PARTITION ACCESS : R/W USER PARTITION 14:27:08 : PERM_BOOT_CFG_PROT : DISABLED 14:27:08 : PWR_BOOT_CFG_PROT : DISABLED 14:27:08 : BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED 14:27:08 : RESET BUS WIDTH : ENABLED 14:27:08 : eMMC FirmW UPDATE : DISABLED 14:27:08 : EMMC CACHE SIZE : 0 KB 14:27:08 : SUPER PAGE SIZE : 3584 KB 14:27:08 : HC ERASE GROUP SIZE: 512 KB 14:27:08 : USER AREA SIZE : 7818182656 BYTES 14:27:08 : BOOT PARTITION SIZE: 4096 KB 14:27:08 : RPMB PARTITION SIZE: 512 KB 14:27:08 : 14:27:08 : 14:27:08 : eMMC Device Information 14:27:08 : Manufacturer ID: SAMSUNG 14:27:08 : Device Type : Embedded BGA 14:27:08 : Application ID : 00 14:27:08 : Product Name : M8G2YC 14:27:08 : Product Rev : 0.0 14:27:08 : Product SN : 308FBC6C 14:27:08 : Manufactured : September 1997 14:27:08 : 14:27:08 : Card Specific Data 14:27:08 : CSD_STRUCTURE : Extended 14:27:08 : SPEC_VERS : Version 4.1/4.2/4.3 14:27:08 : TAAC : 13 ns 14:27:08 : TRAN_SPEED : 4000000 KHz 14:27:08 : READ_BL_LEN : 512 Bytes 14:27:08 : C_SIZE : HIGH CAPACITY 14:27:08 : WP_GRP_ENABLE : YES 14:27:08 : WRITE_BL_LEN : 512 Bytes 14:27:08 : CONTENT_PROT_APP : NO 14:27:08 : PERM_WRITE_PROTECT: YES 14:27:08 : TMP_WRITE_PROTECT : NO 14:27:08 : 14:27:08 : Extended CSD Saved: 14:27:08 : 1501004D384732594300308FBC6C90D7.ext_csd 14:27:08 : Backup Directory: 14:27:08 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 14:27:08 : 14:27:09 : 14:27:09 : Dumping Custom Region 14:27:09 : Please wait for some time... 14:27:09 : Partition Selected: USER AREA 14:27:09 : (eMMC Clock 5000000 Hz) 14:43:28 : 14:43:28 : Custom Block Read OK 14:43:28 : File Saved: C:\AdvanceBox Turbo Flasher\eMMC\Recovered\111111_0x00000000_0x000FFFFF.bin 14:43:28 : 14:43:28 : Total Elapsed Time 00:16:20 SAMSUNG PROTECTION REMOVED Code: 14:43:39 : 2. Connect the Soldered TP Connections to ATF Box 14:43:39 : 3. Disconnect the USB Cable and Wait until the 14:43:39 : the ATF Software will tell you to Connect the USB. 14:43:39 : 14:43:39 : 14:43:39 : Interface Reset OK! 14:43:39 : eMMC Access Type: SECTOR MODE 14:43:39 : eMMC Supported Voltage Range: 14:43:39 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 14:43:39 : 14:43:39 : CID : 1501004D384732594300308FBC6C90D7 14:43:39 : CSD : D02701320F5903FFF6DBFFEF96406007 14:43:39 : 14:43:39 : eMMC Boot Information 14:43:39 : Revision 1.5 (for MMC v4.41) 14:43:39 : BOOT PARTITION : USER AREA 14:43:39 : PARTITION ACCESS : R/W USER PARTITION 14:43:39 : PERM_BOOT_CFG_PROT : DISABLED 14:43:39 : PWR_BOOT_CFG_PROT : DISABLED 14:43:39 : BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED 14:43:39 : RESET BUS WIDTH : ENABLED 14:43:39 : eMMC FirmW UPDATE : DISABLED 14:43:39 : EMMC CACHE SIZE : 0 KB 14:43:39 : SUPER PAGE SIZE : 3584 KB 14:43:39 : HC ERASE GROUP SIZE: 512 KB 14:43:39 : USER AREA SIZE : 7818182656 BYTES 14:43:39 : BOOT PARTITION SIZE: 4096 KB 14:43:39 : RPMB PARTITION SIZE: 512 KB 14:43:39 : 14:43:39 : 14:43:39 : eMMC Device Information 14:43:39 : Manufacturer ID: SAMSUNG 14:43:39 : Device Type : Embedded BGA 14:43:39 : Application ID : 00 14:43:39 : Product Name : M8G2YC 14:43:39 : Product Rev : 0.0 14:43:39 : Product SN : 308FBC6C 14:43:39 : Manufactured : September 1997 14:43:39 : 14:43:39 : Card Specific Data 14:43:39 : CSD_STRUCTURE : Extended 14:43:39 : SPEC_VERS : Version 4.1/4.2/4.3 14:43:39 : TAAC : 13 ns 14:43:39 : TRAN_SPEED : 4000000 KHz 14:43:39 : READ_BL_LEN : 512 Bytes 14:43:39 : C_SIZE : HIGH CAPACITY 14:43:39 : WP_GRP_ENABLE : YES 14:43:39 : WRITE_BL_LEN : 512 Bytes 14:43:39 : CONTENT_PROT_APP : NO 14:43:40 : PERM_WRITE_PROTECT: YES 14:43:40 : TMP_WRITE_PROTECT : NO 14:43:40 : 14:43:40 : Extended CSD Saved: 14:43:40 : 1501004D384732594300308FBC6C90D7.ext_csd 14:43:40 : Backup Directory: 14:43:40 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 14:43:40 : 14:43:40 : 14:43:40 : Task Selected: Samsung Remove Write Protection 14:43:40 : ====================================================== 14:43:40 : --> DO NOT PERFORM THIS ON A NON SAMSUNG BRAND EMMC 14:43:40 : --> Make Sure you BACKUP eMMC DUMP Just In Case... 14:43:40 : ====================================================== 14:43:40 : 14:43:43 : Permanent Write Protection Removed! 14:43:43 : Perform USB Firmware Update if Needed... READ AGAIN AFTER PROTECTION SAMSUNG REMOVED Code: 14:59:15 : ====================================================== 14:59:15 : eMMC Test Point Connection Module 14:59:15 : ====================================================== 14:59:15 : ====================================================== 14:59:15 : 14:59:15 : 1. DO NOT USE THE PHONE"S BATTERY 14:59:15 : 2. Connect the Soldered TP Connections to ATF Box 14:59:15 : 3. Disconnect the USB Cable and Wait until the 14:59:15 : the ATF Software will tell you to Connect the USB. 14:59:15 : 14:59:15 : 14:59:15 : Interface Reset OK! 14:59:15 : eMMC Access Type: SECTOR MODE 14:59:15 : eMMC Supported Voltage Range: 14:59:15 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 14:59:15 : 14:59:15 : CID : 1501004D384732594300308FBC6C90D7 14:59:15 : CSD : D02701320F5903FFF6DBFFEF96404063 14:59:15 : 14:59:15 : eMMC Boot Information 14:59:16 : Revision 1.5 (for MMC v4.41) 14:59:16 : BOOT PARTITION : USER AREA 14:59:16 : PARTITION ACCESS : R/W USER PARTITION 14:59:16 : PERM_BOOT_CFG_PROT : DISABLED 14:59:16 : PWR_BOOT_CFG_PROT : DISABLED 14:59:16 : BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED 14:59:16 : RESET BUS WIDTH : ENABLED 14:59:16 : eMMC FirmW UPDATE : DISABLED 14:59:16 : EMMC CACHE SIZE : 0 KB 14:59:16 : SUPER PAGE SIZE : 3584 KB 14:59:16 : HC ERASE GROUP SIZE: 512 KB 14:59:16 : USER AREA SIZE : 7818182656 BYTES 14:59:16 : BOOT PARTITION SIZE: 4096 KB 14:59:16 : RPMB PARTITION SIZE: 512 KB 14:59:16 : 14:59:16 : 14:59:16 : eMMC Device Information 14:59:16 : Manufacturer ID: SAMSUNG 14:59:16 : Device Type : Embedded BGA 14:59:16 : Application ID : 00 14:59:16 : Product Name : M8G2YC 14:59:16 : Product Rev : 0.0 14:59:16 : Product SN : 308FBC6C 14:59:16 : Manufactured : September 1997 14:59:16 : 14:59:16 : Card Specific Data 14:59:16 : CSD_STRUCTURE : Extended 14:59:16 : SPEC_VERS : Version 4.1/4.2/4.3 14:59:16 : TAAC : 13 ns 14:59:16 : TRAN_SPEED : 4000000 KHz 14:59:16 : READ_BL_LEN : 512 Bytes 14:59:16 : C_SIZE : HIGH CAPACITY 14:59:16 : WP_GRP_ENABLE : YES 14:59:16 : WRITE_BL_LEN : 512 Bytes 14:59:16 : CONTENT_PROT_APP : NO 14:59:16 : PERM_WRITE_PROTECT: NO 14:59:16 : TMP_WRITE_PROTECT : NO 14:59:16 : 14:59:16 : Extended CSD Saved: 14:59:16 : 1501004D384732594300308FBC6C90D7.ext_csd 14:59:16 : Backup Directory: 14:59:16 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ after this witing ext_csd and dump to phone, full flash it and 625 successfully repaired gTs Last edited by gurinder; 12-02-2015 at 10:19. Reason: spelling mistake |
