12-08-2015, 15:40 | #1 (permalink) |
Freak Poster Join Date: Jan 2010 Location: In GSM Field
Member: 1207045 Status: Offline Sonork: 100.1617234 Thanks Meter: 58 | Lumia 630 after flash totaly dead If the Phone is ALIVE 19:20:30 : 1. Power On the Phone and Connect it to the USB Port 19:20:30 : 19:20:30 : If the Phone is DEAD 19:20:30 : 1. Connect Phone to the USB Port 19:20:30 : 2. Press and Hold the VOLUME DOWN and POWER Buttons 19:20:30 : 3. Wait until the Phone Vibrates Shortly... 19:20:30 : 4. Stop Pressing the Buttons... 19:20:30 : 19:20:30 : If the Phone is DEAD BOOT 19:20:30 : 1. Connect Phone to the USB Port 19:20:30 : 2. Install Correct Drivers: 19:20:30 : "Nokia Emergency Connectivity" Located at: 19:20:30 : 19:20:30 : C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\ 19:20:30 : ================================================== ==== 19:20:30 : 19:20:38 : Recovery Handle Found! - (WinUSB) 19:20:40 : PBL Emergency Download Detected 19:20:40 : 19:20:40 : Start Sending Firehose Loader... 19:20:40 : Firehose Loader Sent! 19:20:40 : Executing Firehose Loader... 19:20:41 : Start Processing Firehose Payload... 19:20:41 : MSG_SIGNATURE Sent.... 19:20:41 : Validation is enabled. 19:20:41 : EMMC: size_in_sectors:15269888, mfr_id:144, oem_id:74, prod_rev:1, mfr_date:7/2014 19:20:41 : MSG_HASHTABLE Sent.... 19:20:41 : MSG_XML_CONFIGURE_\8626_edl_fh_image_config.xml Sent... 19:20:42 : MSG_XML_PROGRAM_SBL1 Sent... 19:20:42 : start 53248, num 493 19:20:42 : Finished sector address 53741 19:20:42 : MSG_XML_PROGRAM_RPM Sent... 19:20:42 : start 65536, num 302 19:20:42 : Finished sector address 65838 19:20:42 : MSG_XML_PROGRAM_TZ Sent... 19:20:42 : start 69632, num 690 19:20:42 : Finished sector address 70322 19:20:42 : MSG_XML_PROGRAM_UEFI Sent... 19:20:42 : start 61440, num 2229 19:20:43 : Finished sector address 63669 19:20:43 : MSG_XML_PROGRAM_WINSECAPP Sent... 19:20:43 : start 73728, num 538 19:20:43 : Finished sector address 74266 19:20:43 : MSG_XML_PROGRAM_TZAPPS Sent... 19:20:43 : start 77824, num 1070 19:20:44 : Finished sector address 78894 19:20:44 : MSG_XML_PROGRAM_DBI Sent... 19:20:44 : start 57344, num 36 19:20:44 : Finished sector address 57380 19:20:44 : MSG_XML_ERASE_DDR Sent... 19:20:44 : start 36864, num 32 19:20:44 : Finished address 36896 19:20:44 : MSG_XML_ERASE_PLAT Sent... 19:20:44 : start 167936, num 16384 19:20:44 : Finished address 184320 19:20:44 : MSG_XML_ERASE_EFIESP Sent... 19:20:44 : start 184320, num 65536 19:20:44 : Finished address 249856 19:20:44 : MSG_XML_PROGRAM_8626_gpt_v1_0.bin Sent... 19:20:44 : start 0, num 34 19:20:44 : Finished sector address 34 19:20:44 : MSG_XML_POWER Sent... 19:20:44 : 19:20:44 : Firehose Payload All Sent! 19:20:44 : Waiting for USB Cycle... 19:20:44 : USB Cycle OK! 19:20:45 : Rebooting Phone... 19:22:18 : 19:22:18 : ================================================== ==== 19:22:18 : ERROR: Active Phone Handle was NOT DETECTED 19:22:18 : ================================================== ==== 19:22:18 : 19:22:18 : 19:22:18 : ================================================== ==== 19:22:18 : 19:22:18 : ERROR: Flashing Failed! 19:22:39 : |
01-30-2016, 20:23 | #4 (permalink) |
Freak Poster Join Date: Sep 2005 Location: Russia, Kaluga Age: 46
Member: 179187 Status: Offline Thanks Meter: 32 | Same sh*t happened to me.. ATF 12.55 "21:49:05 : Flash File Checksum Verification 21:49:05 : ================================================== ==== 21:49:55 : RM976_02040.00021.15235.50004_RETAIL_prod_signed_1 182_02785F_000-BY_MV.ffu: CHECKSUM PASSED 21:49:55 : ================================================== ==== 21:49:55 : Verification Done... 21:49:59 : Windows Phone 8/8.1/10 Flashing Started 21:49:59 : Loading Flash Files Please Wait... 21:50:00 : 21:50:00 : [DEAD BOOT REPAIR via USB is SUPPORTED] 21:50:00 : 21:50:00 : ================================================== ==== 21:50:00 : Windows Phone 8/8.1/10 Lumia Flasher 21:50:00 : ================================================== ==== 21:50:00 : 21:50:00 : If the Phone is ALIVE 21:50:00 : 1. Power On the Phone and Connect it to the USB Port 21:50:00 : 21:50:00 : If the Phone is DEAD 21:50:00 : 1. Connect Phone to the USB Port 21:50:00 : 2. Press and Hold the VOLUME DOWN and POWER Buttons 21:50:00 : 3. Wait until the Phone Vibrates Shortly... 21:50:00 : 4. Stop Pressing the Buttons... 21:50:00 : 21:50:00 : If the Phone is DEAD BOOT 21:50:00 : 1. Connect Phone to the USB Port 21:50:00 : 2. Install Correct Drivers: 21:50:00 : "Nokia Emergency Connectivity" Located at: 21:50:00 : 21:50:00 : C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\ 21:50:00 : ================================================== ==== 21:50:00 : 21:50:00 : Recovery Handle Found! - (Qualcomm) 21:50:02 : PBL Emergency Download Detected 21:50:02 : 21:50:02 : Start Sending Firehose Loader... 21:50:02 : Firehose Loader Sent! 21:50:02 : Executing Firehose Loader... 21:50:04 : Start Processing Firehose Payload... 21:50:04 : MSG_SIGNATURE Sent.... 21:50:04 : Validation is enabled. 21:50:04 : MSG_HASHTABLE Sent.... 21:50:04 : MSG_XML_CONFIGURE_\8626_edl_fh_image_config.xml Sent... 21:50:04 : MSG_XML_PROGRAM_SBL1 Sent... 21:50:04 : start 53248, num 493 21:50:04 : Finished sector address 53741 21:50:04 : MSG_XML_PROGRAM_RPM Sent... 21:50:04 : start 65536, num 302 21:50:04 : Finished sector address 65838 21:50:04 : MSG_XML_PROGRAM_TZ Sent... 21:50:04 : start 69632, num 690 21:50:05 : Finished sector address 70322 21:50:05 : MSG_XML_PROGRAM_UEFI Sent... 21:50:05 : start 61440, num 2229 21:50:05 : Finished sector address 63669 21:50:05 : MSG_XML_PROGRAM_WINSECAPP Sent... 21:50:05 : start 73728, num 538 21:50:06 : Finished sector address 74266 21:50:06 : MSG_XML_PROGRAM_TZAPPS Sent... 21:50:06 : start 77824, num 1070 21:50:06 : Finished sector address 78894 21:50:06 : MSG_XML_PROGRAM_DBI Sent... 21:50:06 : start 57344, num 36 21:50:06 : Finished sector address 57380 21:50:06 : MSG_XML_ERASE_DDR Sent... 21:50:06 : start 36864, num 32 21:50:06 : MSG_XML_ERASE_PLAT Sent... 21:50:06 : start 167936, num 16384 21:50:06 : Finished address 184320 21:50:06 : MSG_XML_ERASE_EFIESP Sent... 21:50:06 : start 184320, num 65536 21:50:06 : Finished address 249856 21:50:06 : MSG_XML_PROGRAM_8626_gpt_v1_0.bin Sent... 21:50:06 : start 0, num 34 21:50:06 : Finished sector address 34 21:50:06 : MSG_XML_POWER Sent... 21:50:06 : 21:50:06 : Firehose Payload All Sent! 21:50:06 : Waiting for USB Cycle... 21:50:07 : USB Cycle OK! 21:50:07 : Rebooting Phone... 21:51:07 : 21:51:07 : ================================================== ==== 21:51:07 : ERROR: Active Phone Handle was NOT DETECTED 21:51:07 : ================================================== ==== 21:51:07 : 21:51:07 : 21:51:07 : ================================================== ==== 21:51:07 : 21:51:07 : ERROR: Flashing Failed!" Totally dead Nokia 630.. |
